Item inmber 3 is already sold
1,2,4,5 still available ;)
cheers
Just sold number 5 as well...
only 1,2,and 4 left... and i have interest in all three. so if you want one please post that you will take it below in this thread and PM me your phone number:)
cheers guys.
Edited by CEF11E
would these be good enough to run the autronics or whatever engine ecu programs to tune? the ecu programs only a dos load of shit so i think it would be ok, might be interested.
r u willing to ship to perth if i pay postage?
can u send a PM reply please
cheers
Brad
  • 4 weeks later...
CEF11E,
I'm interested in:
4 x IBM 765D (selling for $100 each)
72MB ram
3GB hard drive
CD rom
13.1 TFT screen
Couple of Q's: Do these have a USB port ? Are batteries available for these ( and charger ) ? Will this run NISSAN Datascan well ? ( the real reason I need it )
Cheers.
P.S. I'm in Sydney.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
