Does anyone feel generous enuff to lend me or let me purchase for like $200 a set of standard R33 wheels with tyres. 5 x 114.3 I need them for prolly a max of a month if you are willing to lend.
And if you are lending the wheels, they will travel a max of like 20km the whole time I have them. 200sx damaged and wheels are all busted. Skyline is okay though, phew!! not my accident but my car so gotta sort something out.
Oh yeah I will take 1 wheel from 4 people if i need to, beggas cant be choosers right.
Any help will be fantastic.
RiaZ
https://www.sau.com.au/forums/topic/9256-any-kind-souls-out-there/
LOL, hey Hick I appreciate the offer mate. I will let you know soon as soon as Paul sorts out these other wheels I want to buy. Hey paul drop me an sms of any sort so I can get ya numba to call you tomoz mate.
Thanks
RiaZ
