MY current BOV is a GFB one, and is a bit shit as it stays open and the spring tension is stuffed, causing the BOV to stay open on idle and accelration sometimes, hence I want to replace it.
Now i am not to concerned about retaining the sound of atmo venting.
IS a plumback substantially better over a atmo venting, from purely a performance perspective?
Furthermore is there any noise emitted from a Plumback? is it at all similar to an atmo venting sound, just lesser volume?
Finally what would be the best Plumback BOV to get, i understand this is fairly objective, but opinions are welcome...
cheers
GTR's have a twin setup.
But, you can use one of them if you please, its requires small mods i think to fit into a stock R33 spot. But when they are so cheap to buy in the first place fitting costs outweight aftermarket ones generally.
I used one of thw two on my pervious setup and it was more than adequate for mine without drama (Search if you wanna know more)
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
