Well, as Autosalon is on here in Brisbane this weekend, I thought it would be a good time for the majority of us skyline cruisers to possibly get together and organise a cruise for tomorrow (Saturday) night as Autosalon closes down at 9pm to get ready for another day on Sunday.
So, who here would be interested in a cruise? Cruise would either start at around 9.30pm for those who have entered into the autosalon and can get their car out saturday night.
Or
Start the cruise at around 8pm for those skylines that can either leave early or did not enter in such as myself.
Those who are interested, please show your interest in responding. If not much of a response is given, then we might just give it a miss. But as the last skyline meet on the thursday night was a good outcome in my opinion, thought as we have a car event on this wknd, would be good to th skylines in a group.
Possibly even organise a few night time photo's as well, which could come in handy for the calander thats in progress as we speak.
https://www.sau.com.au/forums/topic/92743-autosalon-mass-skyline-cruise/
  • Replies 65
Yeah I don't mind going for a drive but it would be best if you described the meeting location, the direction we will be heading, some of the stops on the way.
When you organise a cruise you have to have it all prepared otherwise you won't get any takers. If people see that it looks like just a dodgy 'drive around' they won't bother coming because it looks as though you haven't put any thought into it.
I was just seeing the interest first to see if anyone wants to go through with the cruise. The next step would of been to see if they want to cruise around the city or down to BWCP.
Well.... my plan put forward.
Meet at Springwood Crazy Clarks at 8pm. From there we will leave and head down for a cruise towards BWCP with a pit stop in at Yatala BP. We'll leave Springwood Crazy Clarks right on 8.30pm and no later allowing us to meet up with the leavers from Yatala BP at 9pm.
Meet: Springwood Crazy Clarks 8pm.
Depart meet spot: 8.30pm SHARP!
Destination: BWCP.
Pit Stop: Yatala BP which we will arrive at approximately 8.50PM / 9PM. Depart from their with the others who usually meet at Yatala BP.
Edited by r33skyliner
I'll be there at 8pm.
Those who are within the cbd area. Let me know and we can meet at either coorparoo macca's along old cleveland rd at 7.30 or officeworks along ipswitch road at 7.30.
if no one will respond to wanting at meeting at these 2x locations, i wont turn up then and will go straight to springwood crazy clarks.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
