Just thought id ask what ppl have done about the engine temps rising when yourve put on a front mount cooler, as mines running alot hotter i need to do something about it, i was thinking first ill flush out the radiator,new coolant and colder thermostat to see if thatll work, also does any1 have a part no for the rb20det thermostat
https://www.sau.com.au/forums/topic/9278-engine-temps/
Same prob here, my car now overheats after about 4 laps on the track, something that even on hot days never use to happen. I was going to cut a larger opening in the OE bar, then make some aluminium or fibreglass shrouding to direct ariflow thru the IC and radiator.
If this doesnt help i suppose i will try the thermostat ($$$ and where do i get one from) as well an ARE aluminium radiator just to be sure.
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-139108
i fitted a thermostat from a VL to my 32 and run twin thermofans. With the stock radiator and a very big (600x300x73) fomt mount the temp stays at 80deg, in the last couple of days when it was 40+deg the temp would go up to 90 deg. This is with a new radiator and good cooling parts, so a alloy 32mm radiator is probably the way to go, but for $650+ try the other stuff first.
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-139271
I noticed after I put the FMIC in that the water and oil temps are up by about 10 degrees or so.
I'm putting in a 16 inch davies craig (or is that craig davies??? :spank: ) fan in next weekend. I don't have to, but I noticed that the clutch fan is squeaking and has a slight wobble to it !!! So I'd hate to think what it is like at 6000rpm :)
If your worried about temps, go the thermostat, then thermo fans, then oil cooler or 32mm radiator and see how you go.
J
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-139301
One thing I used to do in my old car cause it used to always overheat in summer, was to drill a 1/8th inch hole in the side of the thermostat so it would always bleed a bit of water through slowly.
Not sure if it was a good idea, but it worked great.
J
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-139334
Guest nismogtsx
In my old skyline it heated to much so i removed the thermo stat alltogether... It took the car ages to warm up but then it always stayed at 1/4 temp... basiclly just off cold..... It olny ever reached over the 1/3 area when doing a big mountain climb in summer is 2nd gear all the way at 3000+rpm all the way...
Not a good idea tho... But i need to in this model due to a very strange setup of FMIC/Radiator blah blah blah
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-139358
Originally posted by lowlux
yeah jay a guy at work told me to do that,he did that in his race car and it worked well, oh well ill try the colderthermostat first,if that doesent work ill drill
LOL cool, I'm glad I'm not the only dodgy person around :P
I saw a Nismo 86 degree thermostat somewhere, but they wanted about $120 or something like that for it. !!!
But then again, it did have the nismo name !!
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-140135
Hmmm...44deg or whatever it was in melb the other day and i was driving around a bit - temp didn't.even move past the normal level. Was quite impressed!
The standard ECU should regulate it all pretty well assuming everything else is working.
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-140256
I've got a pretty big front mount, oil cooler, 1 fan etc and aftermarket ecu etc and the temp sits at 75-78 depending on the outside air temp. On sunday's cruise where it was VERY stop start and 40 farkin degrees, the temp crept up to 81 but that's as high as it's gone AFAIK.
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-140645
Is that oil temp or water temp???
My oil temp was sitting on about 90 degrees while on the highway (110km/h) and sat on around 75-80 when putting around.
The oil coolers must work pretty good (Jay put's one on his shopping/wish list!!).
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-140660
I've got a 90mm I/C ,a 32mm PWR radiator and a big ass oil cooler. On hot days water temps reach 90-94 degrees. Normal days water temps are about 80 degrees. Don't know about winter yet.
Oil temps have never passed 90 degrees on the road. At the race track however, they've reached 120 degrees on 30+ days. I won't be happy until the water temp guage sits in the middle on 30 degrees+ track days.
https://www.sau.com.au/forums/topic/9278-engine-temps/#findComment-144970
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
