Hey guys, i recently installed new plugs, about a month ago, anyways, i got plugs with a .8 gap, im pretty sure they are anyways. i dont wanna pull em out to find out really :s, alot of mucking around esp if i find out they are .8
Anyways, i set my boost for 9.5psi pretty much.
anyways, when i floor it, the car seems to jolt n jerk a little bit. Then it will come onto power. Weird.
Just wondering if this is the ecu doing this, fuel pump, or plugs?
which is the most obvious reason?
am thinking about getting a remapped r32 ecu put in for the time being.
What are the costs in tuning one of these for an r33?
The car has an r34 gtt intercooler, cat back exhaust and k&n panel filter. Stock dump and stock cat
Edited by Coupe-This
https://www.sau.com.au/forums/topic/92850-increased-boost-and-odd-problems-s/
hehe okie, wont do the r32 ecu, just save up for pfc. As for fuel pump i thought about this, and i made a thread bout wot fuel pump, as i think the bosch 040 has problems with letting the tank under a qtr. prefer a pump that i can take down a lil lower than that :(
Could be coils but I think it may be the std ECU seeing too much airflow. I found this when running 9-10psi and R34 intercooler. Actually the R34 intercooler is what sort of set it off. I think at the same boost the air flow is a bit higher. Also the ramp up in airflow is what the stock ecu sees s a problem and richens up the mixture and retards the timing. I thought it was coils but it wasn't. The powerfc with even just the base map runs a lot better - no hesitation now.
It would be good if you could borrow a mates PFC to see if it helps.
If found asyou rev out sometimes it would start going really slowly from 5k rpm on - in 4th gear a couple of times up[ a hill I hit what felt more severe than a rev limit...this was at 3.5k as boost came on. Feels really severe as if you have broken something and instantly take your foot off accelerator
If your after cheap fix then get a SAFC or jaycar fuel adjuster but the PFC is much better.
Edited by benl1981
yeah it was running rich, cld smell abit of fuel when hammering it, just weird, seeing as its only on lowish boost and already getting that problem, damn it. Mite have to invest in a pfc when i get back from my holiday :s, good old c/c, lol
I had my car on about the same boost level as you last weekend on the way to avoca.. if I 3/4 throttled it so that it was about 8psi it'd gun it, as soon as I went full throttle 10psi it'd rich and retard, wouldn't accelerate till it settled down or I backed off the throttle..
It's a protection mechanism for the ECU, you could try maybe a SAFCII - not sure if this would make a difference..
thats what i was confused about, because it would act stupidly then go fine, although if i backed off from full throttle to about 3/4 like u said, it seemed like it picked up a bit of power, haha damn cars. Might have to invest in a power fc one of these days
Yes - I would find on 1/2 throttle my car would be quicker - especially running 10psi boost. Powerfc has fixed this..hoping to gain some more average power after a tune.
The stock computer is crap for anything above stock boost. Unlike other cars that are ok if you turn up the boost a bit.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
