Hi just wondering if anyone knows the difference between a R34 GTT 4 dr and a R34 GTX 4 dr.
Has the GTT got better suspension over GTX? I think they both have the same engines?
and do any of the 4 drs come out manual, all the ones I've seen seem to be autos, with manuals in the 2drs.
I have seen a few on the net and am interested to know..
Stephen
https://www.sau.com.au/forums/topic/93080-r34-gtt-4-dr-or-r34-gtx-4-dr/
GT-X is the top of the line luxury model.
and GT-t is just like the equivilant of the GT-t 2 door. I'd get the GT-t if i was you. Unless performance is the last thing on your list. And in that case i'd get the GT-X
All the specs you need are here
http://www.motortraders.net/imports/select...yline&period=73
In a nutshell, you have...
25GT sedan in auto only
25GT FOUR sedan in auto or manual and 4WD
25GT turbo sedan in auto or manual
25GT-X sedan auto only
25 GT-X FOUR sedan in auto only
25GT-X turbo in auto or manual
Edited by vrfour
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
