from memory, u gotta pull bottom part up outa its clips frist then slide it outwards.
then to do top part u remove to bolts at bottom at each end then slide it up off its hooks, just becareful when putting back in that u don't bend the hooks otherwise will be harder to put on.
  • 4 weeks later...
That is the correct way to remove them........if the base has been in there a while it can be tad difficult to remove.
Basically you just need to sit behind you Front seats facing the back of the car......in a squatting position....then push the front of the base towards the back of the car and upwards at the same time.....it will then release......i have had some seats that required a bit of coaxing with a long screwdriver lol.
The to remove the backrest, just follow the instructions given above by skypy
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
