I dont do air con "fixing" but whatever parts you need I can get pretty cheap.
If you need to go to someone who does aircon, I would recommend Tuggeranong Auto Electrics, the guys there are really cluey and good with Jap cars... If hes there you should try to speak to Stuart. :D
  • Replies 63
Oh, I would need to know exactly what the pipe looks like and what side it is on the air con system, then I would need to know what kind of fittings it has on either end (beadlocks, o'ring, pad or flange) then once you had the new pipe on it would need to be regassed anyway, and if its not R134a gas then its R12 gas and will have to be changed so you might need a new reciever drier aswell.... Complicated enough for you?
Heh heh :D Sorry I just like to prove how car smart I am sometimes... If you go to Tuggeraning Auto Elec they'll know exactly what pipe you need, then they'll call me and order it... So ill be getting it that way anyway :(
Well, its been nice being able to log on here all day recently but I wont be able to from tomorrow as the user of this computer will be returning to work and I will be forced to use the other computer again (which has no internet) so I will only be checking in after work... Just thought Id let you know :D
I thought so, I see your car everytime I go round to rinse off my car ( I park under a tree at work)...
I havent seen you do anything stupid yet :)
I work at Ingrams on Townsville street, pretty much straight across from the post office.
If you ever need anything Auto electrical or air con, drop in and see me, ill look ater you cos your a Skyline man :P
thanks man is there anyway to fix the dodgy off button on the 33 if anyone else has had the problem when it tilts to the side and doesn't work anymore
and yeah you would see me alot I'm addicted to the sausage rolls from the bakery next to the news agency
Slither, you work in Fyshwick dont you... Just off of Canberra Ave.
I see your car heaps.
Hi Slither:ditto R31DET's comment-spotted you car a number of times. VERY neat,I'd say. Top colour,too! Congrats!
Yeah mate i've had this problem. what happens is the button has a hinge that attaches it from the top allowing it to be pressed in. this has broken. oyu just need to either glue it back together, or what i did, was glue a bit of plastic behind it to stop it rotating. if you pull it off you'll see what i mean.
Just checked this thread again thanks for complement
as for the button sounds like a bit of effort to pull it apart think i'll just put up with it always been on
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
