I dont do air con "fixing" but whatever parts you need I can get pretty cheap.
If you need to go to someone who does aircon, I would recommend Tuggeranong Auto Electrics, the guys there are really cluey and good with Jap cars... If hes there you should try to speak to Stuart. :D
  • Replies 63
Oh, I would need to know exactly what the pipe looks like and what side it is on the air con system, then I would need to know what kind of fittings it has on either end (beadlocks, o'ring, pad or flange) then once you had the new pipe on it would need to be regassed anyway, and if its not R134a gas then its R12 gas and will have to be changed so you might need a new reciever drier aswell.... Complicated enough for you?
Heh heh :D Sorry I just like to prove how car smart I am sometimes... If you go to Tuggeraning Auto Elec they'll know exactly what pipe you need, then they'll call me and order it... So ill be getting it that way anyway :(
Well, its been nice being able to log on here all day recently but I wont be able to from tomorrow as the user of this computer will be returning to work and I will be forced to use the other computer again (which has no internet) so I will only be checking in after work... Just thought Id let you know :D
I thought so, I see your car everytime I go round to rinse off my car ( I park under a tree at work)...
I havent seen you do anything stupid yet :)
I work at Ingrams on Townsville street, pretty much straight across from the post office.
If you ever need anything Auto electrical or air con, drop in and see me, ill look ater you cos your a Skyline man :P
thanks man is there anyway to fix the dodgy off button on the 33 if anyone else has had the problem when it tilts to the side and doesn't work anymore
and yeah you would see me alot I'm addicted to the sausage rolls from the bakery next to the news agency
Slither, you work in Fyshwick dont you... Just off of Canberra Ave.
I see your car heaps.
Hi Slither:ditto R31DET's comment-spotted you car a number of times. VERY neat,I'd say. Top colour,too! Congrats!
Yeah mate i've had this problem. what happens is the button has a hinge that attaches it from the top allowing it to be pressed in. this has broken. oyu just need to either glue it back together, or what i did, was glue a bit of plastic behind it to stop it rotating. if you pull it off you'll see what i mean.
Just checked this thread again thanks for complement
as for the button sounds like a bit of effort to pull it apart think i'll just put up with it always been on
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
