just for general knowledge my power steering pump was leaking and i had an extra pump from the ca18det engine, i got it to work, all you need to do is change the brackets, that is, use back you brackets from the rb 20 pump. the pump works fine no problems. by the way its the stock rb20e engine in the cefiro, not sure if it would work with othe rb engines
  • 1 month later...
thought i should post this here also for reference:
Ok i think i have figured the Transmission Mount formula, with the knowledge i have put together from two AT to MT R32 swaps, one AT to MT S13 swap, and one MT RB to MT SR mission swap.
ok heres what we have to start....
TOP: S13 SR mount for a factory MT car
MIDDLE: RB MT Mount for a car that is factory MT (not converted)
BOTTOM: SR custom MT mount made for a Cefiro that came factory with a AT
note: these are all facing the correct way
so i have determined....
R32: for a R32 RB20 factory AT to be converted to a MT you need the S13 MT Mount to install (TOP)
A31: Same for a A31 RB20 factory AT to be converted to a MT you need the S13 MT Mount to install (TOP)
A31, R32: For a factory RB20 AT car to be converted to a SR20 MT you will need a custom mount (BOTTOM) and the S13/S14 Engine Mount also.
A31, R32: for a factory RB20 MT car (like mine) to be converted to a SR20 MT you will need the S13 MT mount (TOP) and S13/S14 Engine Mount also. oh and the 130cm S-Car drive shaft (measured from tranny end to diff tip)
Example of the (BOTTOM) custom mount where the (TOP) S13 Mount should be, maybe can get two holes to line up if i didn't have the Uras Urethane-Mount installed...
in think that covers what i know so far...
  • 3 months later...
this is in regard to the z32 calipers on r33 na gts 4 stud discs.
z32 alloy calipers came out for 26 mm thick discs and 30mm discs. there were also z32 steel calipers that were 30mm.
now for this fairly simple upgrade to work u will need the 26mm calipers not the 30 mm ones.
http://www.princeton.edu/~asad/zbrakes/
Edited by Resin
Rear subframe?
They fit, (I have an S13 rear subframe in mine), but the handbrake setup on the hubs is different, requiring either custom handbrake cables or installation of cefiro/skyline hubs. Why anyone would install an S13 rear subframe is beyond me.
  • 3 weeks later...
Parts for 5stud conversion and r33 gtst brake upgrade
Brake Master Cylinder BM44 off r32 gtst skyline
s14 front hubs and Lower control arms
front r33 gtst calipers and discs
Rear r33 hubs and discs and calipers.
Swap the a31 handbrake cable over in the hubs as the r33 is too long. The handbrake drum setup are exactly the same.
also look at getting new brake lines from the arch to the caliper all round as the r33 ones work but dont hook up to things the same way as the originals so will wear alot more.
and 5 stud wheels
  • 3 weeks later...
The rear hub uprights (aka hub carrier... the solid cast iron thing which the control/toe arms bolt to) are identical to S13 (and I would assume R32).
You may be thinking what use would that have, well I had enough trouble finding a pair of rear cefiro hubs complete with calipers/discs/handbrake assembly then it turns out that the upright was bent, so then I had to try sourcing an individual cefiro rear left hub upright.
This also means it is possible to do skyline rear brake upgrade to S13 and stay 4 stud (for those people who prefer to remain 4 stud).
im in the uk and very very few cefs here so finding parts is a joke
i have a redtop sr20 in mine so its not a problem but a mate of mine has an rb20det cef and he is struggling to find a bloody alternator belt .. he bought one for an rb20 ( r32 one ) and that was to long .. someone suggested a CA18 one but he not sure ??
any info would be great
thanks very much :blink:
They're different to an R32...
Alternator Belt: 4PK860
Powersteering without Aircon: 4PK925
Powersteering with Aircon: 3PK845
Those are Gates belt codes, you might need to check if other manufacturers use the same code.
Just checked... Optibelt's Alternator Belt code is 4PK858, Goodyear's is 4PK0863, Dayco's (Pirelli) is 4PK862, and Quinton Hazell's is QBR4863.
Enjoy
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
