  • Replies 73
Originally posted by Majanal
UFO... the place to speed is at the race track (or private road)... you know that!!!
Are you coming out past Oran Park on the 16th? I'll take you for a spin in my car if you like!
Dan.
Dan,,,They have roads with unlimited Speed Signs,,,,I've got the speedo now,,,I wanna see just how fast she goes before Selling Her.
Not sure about Oran Park though,,,see what happens,,,thanks for the offer.
Neil.
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-143147
Neil.
Yeah I know mate... I knew that was what you ment... just covering my arse!!! and leading up to the invite I gave u... well if I see you at oran park I'll chat to you then.
Also... all u NTers that have replied... I'll offer you a free ride on me if you turn up at oran park!
Dan.
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-143275
  • 3 weeks later...
There are at least 6 skylines in Darwin but at the present they still seem to be relatively exclusive. I was the second person in Darwin to purchase an R33 GTS25t back 3 years ago. There are probably more because there is a continuous coming and going of young army recruits bringing them up.
For the person that was asking about the best place to speed well if you are sitting in the middle of Darwin you drive 30 to 40km's down the stuart highway until you see a sign with a white background and a black circle with a black line through it diagonally. At that point you would be doing 100kph in 5th and all you do is to push your accelarator to the floor until you are screaming along in fifth. My only problem is i have a standard 180kph speedo and all that i can tell you is that i have had it wrap around to zero and then some. I would guess i was doing around 240kph (screaming along in 5th). Once i slowed down i found that one of the plastic ferrings in front of the drivers side front wheel had been forced against the front wheel and had melted. Neat huh.
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-169099
hahaha this week you can grab it, probably tuesday or wednesday!
As for the exclusive part i dont think its so much as exclusive, its just the smarter people dont go around cruising and harassing others on the road with PCHHST noises in the window like the other fools on the road.
And some of us are picked on by the cops for having a loud car..... but thats only when the external gate opens up :)
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-169189
Hey... good to see you all!
I'll have to come up one day and try this speed thing... I have a digital speedo thing in my car... have seen it pass 200 down main straight on Easter creek... but then the straight runs out!
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-169353
Good to see you guy's in here,,,Great stuff,,,,but I have many questions to ask. What fuel are you guy's using would have to be the 1st one.
R33NT,,,,Great story buddy but I won't be in 5th @ 100kmh ,,,I'll be in 3rd ready to plant my right foot,,,,I wanna see if I can pull redline in 5th.....
Neil.:D:) :) :) :) :) :) :) :) :)
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-172225
Our fuel up here is at best PULP 98RON i think (103.9c/L). I get the best results with BP PULP and the worst with Woolworths Plus Petrol PULP.
We dont get the same luxuries you guys down south get, shell optimax (droool).
Low RON fuel plus high ambient temperature is not the best combination but we get by.
I read yesterday they are going to charge people who drive dangerously ie to fast for the situation (in the no limits area) !!!!
As for the speed cut i just installed an Apexi PowerFC!
https://www.sau.com.au/forums/topic/9362-calling-all-nters/#findComment-174893
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
