Couldn't really find to much info when i searched. Other then oil squirters on the pistons? And 10.5 compression compared to 8.5 in the det?
Does anyone know what the differences are between the rb20de and the rb20det?
Just done the big end bearing in the det, and have got a de motor. Put a highmount manifold on it, series 2 (steel wheel?) rb25 turbo, external gate, walbro fuel pump, sard fpr, safc 2 with a cheap boost controller, front mount and 3" exaust.
Not really to sure of the power i'm expecting, or even how much power the de will handle before it pops.
Has anyone got any differences on the 2? How much boost they can handle? What sort of power figure i am looking at (Been told high 200hp with a fair bit of boost)
Just a bit worried as it's just been dropped into the car and is havin the gate and turbo fitted this weekend. Gets tuned some time during the week, wanna make sure i don't push it to hard or whatnot.
Regards,
Chris.
Edited by 51OWW
https://www.sau.com.au/forums/topic/93718-rb20det/
No piston oil squirters in the n/a I believe.
You could pull the sump off the n/a and double check for us though.
Static compression is also much higher, up around the 10.5:1.
As its running quite a high static comp it will be very interestering how it goes with the Rb25 turbo.
You say you've bolted an external gate on it?!?! The RB25 turbo is internal or have you welded up the internal gate?
With such a high static comp ratio it will feel very N/A like, you won't need much boost to make good power but thats pretty much where it ends.. You will be limited with the amount of power you can make.
With an rb25 turbo I'm sure you will get close to the 260-270rwhp mark.
I would use the cams from the DET head (cams are slightly bigger) and use a pair of adjustable cam gears to dial in some overlap.
It will be fine with good tuning and good fuel...
Just be sure to keep a close eye on those knock levels via the pfc h/c.
Edited by Cubes
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1692907
Rb25 is internal gate, but been modded to run external (not by choice, with the top mount it doesnt fit between the turbo and the motor :D)
I might stick with ~250rwhp for a while just to see how the motor holds up... Initial plans where to gas it and see what happened, though, i gotta get the det rebuilt first. (main reason i haven't played with cams etc) 250 in the silvia should be enough to keep me drift happy for a lil while anyway.
pfc? Be nice to have, but i went el cheapo safc aha - not 100% sure if it's got knock sensor... actually come to think of it, it might do - i remember it had something over the emanage that made me buy it? *shrugs*
Also just noticed there was a thread in the na section relating to this topic, so i've had a read through that. :( Though, noones actually said what power it'll take to blow the lil de...
Regards,
Chris.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1693030
Using the SAFC in your position is quite a bad thing.
If its running rich and you lean it out your telling the ecu there is less air entering the motor to get decent afr's.
As a result you shift up on the load map. As you move up the map closer to the idle and light cruise load points the map contains much higher ignition timing. Of which is very very bad for such a high comp motor.
The SAFC II monitors knock i believe.
The DE will be fine providing the tuning is good. That being no detonation and good afr's.
Good luck... Your going to need it without being able to manipulate ign. timing. :D
Edited by Cubes
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1693186
B) She's apples. Hopefully i'll get out of it ok, and have a reasonably reliable motor...
Anything else i should be monitoring though while it's on the dyno? I'm not tuning it personally, though, have a mate doing it :P He seems to know what he's doing ahaha.
Regards,
Chris.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1693399
*sigh*
Had the motor up and running today, drove it 100m, without the safc (just to see if it drove) Bam! Turbo blew up. exaust wheels are smashed, really bad :cheers: and, there also seems to be a knocking from the engine - maybe lifters, though, i fear another big end bearing :D Thats what the last engine was replaced for, what a waste of money for 100m test drive. Coulda got a lot of taxi rides with it :(
Throwing another turbo on it tonight - hopefully it'll run fine... *fingers crossed* though i doubt it. Very much. ;)
Regards,
Chris.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1695967
Oh well. Suppose i better keep it updated.
Chucked a new rb25 turbo on it. Drove ok, though, didn't get up it (not tuned)
at the moment its just high mount, rb25 turbo, external gate, exaust, front mount. So i was a bit iffy to get up it, just let the gate open up then i'd change.
Drove 2k's - 2nd turbo blew up.
Pulled it off, the manifold has bits of weld on the inside falling off, going through the exhaust wheel. So, not good. Getting that fixed up tomorrow, then putting, yet another rb25 turbo on it :D
Probably won't have a chance to boost it hard and see how it goes compared to the old det until it's tuned. Which should be about another week...
Also after turbo died, we checked compression
160 accross all except 140 cyl.3 So, it's not that far of the det's ratings at the moment. So i really doubt there will be much change if it was just a straight swap.
Regards,
Chris.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1704622
Just an update.
Got the manifold all cleaned - put the new rb25 turbo on it. Took it for a drive and it was all sweet for about 5k's.
Then bam. Motor is not very healthy ahah. Piston rings are initial thoughts, though, won't know until the motor is pulled apart.
Note to self - buy a pushbike.
Regards,
Chris.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1726776
Yer it looks as though it's going to be off the roads for a little while. Still haven't pulled te motor out to actually see what went wrong. Not really sure which motor will be better to fix up - big end bearings on the det, or something (hopefully minor) piston related on the de.
*sigh*
Gotta love cars. :(
Regards,
Chris.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1743905
Sticking with the det motor, fixing the big end bearing and whatever else is mangled.
Shouldn't be *to* much longer, hopefully, it'll last a little whlie this time ahah.
Maybe i'll drive it like a grandma :P
Regards,
Chris.
let me know how you go with big-end and main bearings, as ive been told that everyone lists the wrong ones for the DET, im doing my silvertop at the moment, i have a DE motor here and was going to do the same as you but now i think i will pass on that idea
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1781073
Aha, good idea staying away from the de motor. It'd probably be fine with good tuning etc, but, i'll never risk it again.
The guy i have rebuilding the rb20det, plays with them all the time - so he shouldn't stuff it up :D Though, i haven't gotten through to him in about 2 weeks, has stopped answering the phone. Aha. I windge and complain alot though, so i don't blame him. Will answer it the day it's ready so i can't windge at him :( Ahah
Hopefully b4 christmas :)
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1783715
hey does anyone know the difference between the DET head and the DE head as mine have different part numbers on the casting, maybe cause the DE came out of a ceriro?
The DE engine cylinder head have smaller combustion chambers. I have not yet measured them, but you can see the difference in the depth between the two. All of the other parts like valves,cams,springs and the like are different but you can interchanged them without too much trouble.
https://www.sau.com.au/forums/topic/93718-rb20det/#findComment-1788798
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
