  • Replies 42
i had 'exhaust tech' in adelaide install the front mount. they used a rb25det kit (r32, 33 i think). the front bar needed to be modified a bit, nothing too serious, just a trim. the cooler fits perfectly you can hardly even notice it. the pipe work required one hole to be cut in the body and the window washer bottle was replaced (too big).
sorry i cant really give a step by step guide as i had this item proffesionally installed. i did watch the whole process so i may be able to answer specific questions.
cheers, doug.
ps, this car will be advertised on carsales.com soon and also local adelaide papers.
https://www.sau.com.au/forums/topic/93976-wanted/page/2/#findComment-1724494
Well, as he said, it seems the R33 GTST one lines up all fine and stuff. So any hybrid/chinese style cooler pipes.
So basically, any jap pipe kit would work, but the issues with those pipes kits is that you have cut a hole in the body under the battery tray, where here in tightass victoria, that could cause problems with the po-leece. Naturally, the water bottle needed to be moved, ive noticed that in the stagea they are extra extra large (i think i put 3L in mine last time i filled it up)
Its good to know now that the R33 GTST pipes fit. Thanks mate.
Edited by AlexCim
https://www.sau.com.au/forums/topic/93976-wanted/page/2/#findComment-1724567
yeah, the washer bottle does the front and back. its also got 2 motors on it. the one that i had put in is from a s15 i think and only has one pump. so when i squirt the water i wash the front and back at the same time!! its actually pretty cool.
my stagea is silver. (and for sale, and in ADELAIDE :)
yep, the r33 kits do the job perfectly, they come with instructions for those who are techinally minded. also you have to trim the radiator fan, i forgot that bit, its in the instructions...
https://www.sau.com.au/forums/topic/93976-wanted/page/2/#findComment-1725601
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
