  • 1 month later...
McCracken,
The point of wrapping the exhaust is to do it correctly.
Having said that a semi-moron can do the job properly and it will never crack.
* clean the surface to be wrapped.
* spray 1 coat of silicone based high temp exhaust paint
* Properly cure the paint. Go for a drive /let it cool, go for a drive let it cool (as per paint instructions)
* Re-coat if necessary
* wrap the pipe EVENLY. Do not wrap the same section of pipe several times for good measure, just do it to the same coverage all round (as per instruction).
* Apply a final spray of high temp paint.
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-240667
Great - thanks Dave for the advice.
Can you suggest a way of curing the paint without having the pipe on the vehicle? I figured doing the wrapping would be much easier before the pipe is on the car.
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-240856
I've found myself some exhaust heat wrap from Autobarn - the brand is High Energy, $90 for 50mm X 15m, and the paint $16 for a can. Picking it up tomorrow night.
Still not sure how I can cure the paint? Is this ultra critical? Would it be ok to paint it, let it dry and then wrap it?
The 'best ideas' I've had so far include wrapping it in foil and cooking on the BBQ, or heat up the oven then stick in one end of it (as it won't all fit - then do the same for the other end).
As you can see I really don't have any good ideas! :D Maybe the instructions on the paint can will help.
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-253283
I wouldn't mind getting my full 3inch stainless off the turbo coated...
any idea how much and how long it'll take ?
and does anyone know if it'll make the thing quieter for me ??
PS. DOES ANYONE KNOW A PIZZA HUT MANAGER ?
we can cut a deal with the boss (we'll buy dinner/breakfast there) and slide the pipes through their oven...the surface scrolls so the pipes don't have to move around...
I think Hungry Jacks will work too...even Route 66 if it still exists...
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-273026
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
