  • 1 month later...
McCracken,
The point of wrapping the exhaust is to do it correctly.
Having said that a semi-moron can do the job properly and it will never crack.
* clean the surface to be wrapped.
* spray 1 coat of silicone based high temp exhaust paint
* Properly cure the paint. Go for a drive /let it cool, go for a drive let it cool (as per paint instructions)
* Re-coat if necessary
* wrap the pipe EVENLY. Do not wrap the same section of pipe several times for good measure, just do it to the same coverage all round (as per instruction).
* Apply a final spray of high temp paint.
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-240667
Great - thanks Dave for the advice.
Can you suggest a way of curing the paint without having the pipe on the vehicle? I figured doing the wrapping would be much easier before the pipe is on the car.
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-240856
I've found myself some exhaust heat wrap from Autobarn - the brand is High Energy, $90 for 50mm X 15m, and the paint $16 for a can. Picking it up tomorrow night.
Still not sure how I can cure the paint? Is this ultra critical? Would it be ok to paint it, let it dry and then wrap it?
The 'best ideas' I've had so far include wrapping it in foil and cooking on the BBQ, or heat up the oven then stick in one end of it (as it won't all fit - then do the same for the other end).
As you can see I really don't have any good ideas! :D Maybe the instructions on the paint can will help.
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-253283
I wouldn't mind getting my full 3inch stainless off the turbo coated...
any idea how much and how long it'll take ?
and does anyone know if it'll make the thing quieter for me ??
PS. DOES ANYONE KNOW A PIZZA HUT MANAGER ?
we can cut a deal with the boss (we'll buy dinner/breakfast there) and slide the pipes through their oven...the surface scrolls so the pipes don't have to move around...
I think Hungry Jacks will work too...even Route 66 if it still exists...
https://www.sau.com.au/forums/topic/9426-hpc-group-discount/#findComment-273026
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
