Hi all,
I noticed that in my 34, I have to step on the brake pedal a fair bit more to get it to stop. The feel of the brakes are poorer at very low speeds e.g. 5-10km/hr.
Stopping from normal speeds is okay, but when you slow down to 5-10km/hr, you have to give the brakes a little push further to bring it to a complete stop.
I am used to driving new cars where you can just step on the pedal at a constant rate and it will come to a stop.
I don't know whether this is just how the brakes are or whether something is wrong with mine.
Can anybody offer any insight?
Thanks
https://www.sau.com.au/forums/topic/94329-brakes-in-a-34-or-any-skyline/
Car was only complianced last month, and unfortunately I do not have a service history for it. Pads look good ie. plenty of meat on them, I might just have to do a brake fluid flush coz it probably has never been done.
How much fluid is needed when bleeding brakes on a 34? Id say it would be the same as a 33 right>?
Edited by nuffsaid
You can do it with a 1 litre bottle but sometimes it takes just a fraction more which is annoying. It should have new pads and fluid from the compliancing so perhaps there is an air bubble in there.
Either way, bleed your brakes and get back to us.
Just checked with compliance people who did my car, brake fluids were replaced last month and pads would have been replaced with Nissan pads if less than 50% were used up.
My pedal feels quite hard when braking, it feels as if the pads arent gripping the rotors properly. Will check them out this weekend.
It may be your pads....if you have pads which are more track oriented than road oriented, they might need to warm up a bit before they start working well.
..but having said that, I reckon the brake pedal in Skyline feels totally different to the brake in any other car.
Mechanics have said that the ABS is working fine and the brakes are fine. Checked the vacuum lines and everything is good.
I think the pads may be a slightly hard compound making the feel not that great. They also said I am probably not used to driving a big heavy car also.
First of all, and believe it or not, the R34 Skyline is not a big heavy car when compared to local products. From memory, the the Skyline is nearly 300 Kg lighter than the BA Falcon. It may be heavy when compared to some fibreglassed monster but at 1350 kg does not rate in the heavy catergory.
I use EBC Greenstuf pads and these suckers will just about put you thru the windscreen. Their temp range is 50C to 650C, have next to no squeal when cold and only need one application to come up to temp from cold. Do not suffer from fade on street and spirited driving use, next to none in brake dust and are relatively gentle on the rotors.
Definitely sounds like you may have a bubble.
Cheers and good luck
Muz
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
