You could also try RHEMAC MOTORS in Gawler,they have had many years exp with all types of engine maching (most workshops around adel have their m'cing done by RHEMAC!) they have state of the art workshop and are very professional in all they do!Give DES a ring and see what he can do for ya..
Regards,
SKYLINE (Kym)... B)
https://www.sau.com.au/forums/topic/94363-rb25det-rebuild/#findComment-1704270
hi, i recently had my RB25 rebuilt at boostworx, they organised all the parts, machining ect for me. i would recommend them.
Sambo33,
If you don't mind me asking, how much did it cost you all up and what was done? U can PM me if u like.
https://www.sau.com.au/forums/topic/94363-rb25det-rebuild/#findComment-1705321
I'm having a good experience with allen engineering, they have given me some great advice - and really know what they are doing.
The best thing is they were one of the cheaper quotes I'd gotten, and they are a proper engineers, not just a mechanic who does a wheel alignment and a spark plug change in the morning and bolts a few engines together in the afternoon. :)
The only thing that may put you off is the fact they are out in mallala (45min drive from the city) - and you probably wont be able to leave your car there (i just dropped the engine parts off).
https://www.sau.com.au/forums/topic/94363-rb25det-rebuild/#findComment-1705866
One of the guys I know got his SR20 rebuilt by Nisspeed. Might be worth checking them out...
I think you'll find Boostwork simply use Nisspeed for engine rebuilds. Nisspeed have done alot of RB25DETs over the years......not mine .....yet :(
https://www.sau.com.au/forums/topic/94363-rb25det-rebuild/#findComment-1707304
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
