Hi everyone,
the car is a near stock (cat back exhaust and POD) a31 Cefiro, factory manual RB20DET. I've just changed the motor for another from a wrecker because the old one cooked and had very bad compression. I purchased an automatic spec a31 rb20det (but with clutch/flywheel on back), but switched over the loom, ecu, sensors, injectors, coils, plugs, ecu, flywheel, box, etc. Previously the old engine with these parts ran fine apart from being gutless and overheating.
Now the engine seems to be running on 5 cylinders. It sounds like a wrx and unplugging the coil for cylinder 1 has no effect. I switched coils and plugs for cylinders 1 and 2 and the problem remained for cylinder 1 only, leading me to believe the coils and plugs are ok.
I then unplugged number 1 injector plug, which made no difference to the running of the engine. Multimeter at the loom plug for this reads 0.7volts while running so I figured I had a busted injector.
Switched it for a spare today and it made no difference. This fresh injector clicked with 12v applied so it shouldn't be seized.
I ran the eccs diagnostics and got code 54: Signal Circuit From A/T Control Unit To ECM which puzzles me. The car is factory manual with the same electronics as before, so why would it be telling me it wants an auto signal? Only thing I can think of is that I've missed a plug somewhere switching the looms, if so where might it be?
Anything else I can try?
I hope people don't just dismiss this as another coilpack fault without reading because I'm sure it's not from my tests. Thanks in advance for any assistance, this has me stumped :)
Edited by l6a6w6s6
https://www.sau.com.au/forums/topic/94410-running-on-5-cylinders-not-coils/
I wouldn't worry too much about the ECU error code right now.
It would appear that one of the wires to #1 injector has a break in it somewhere. Use your multimeter to check continuity of the wiring. 1 side will connect to the ECU (possibly pin 101). The other side is +12V when the IGN is ON.
Ok, did some tests. Both injector wires measure 12v when ignition is ON and no engine running. Tested continuity for pin 101 (white with silver dash) and it matches one pin of injector plug, pin 109 (white with black stripe and silver dash) matches the second injector plug.
I've also tried two different ecus, one an a31 manual and the other an a31 auto and the car runs exactly the same with each, and also they both give diagnostic code 54.
Any more help is appreciated.
Have you actually tested spark output from Coil/Cyl 1?
If you don't have spark it will be a faulty ignitor module (on top of cam cover at rear of motor).
The ignitor module has a transistor for each cylinder that switches the coil on and off for spark! So if the transistor is stuffed for Cyl 1 it will never spark.
It could also be a faulty/broken wire that goes into the module as well for cylinder 1.
If you measure +12 on both sides of the injector plug i would say the injector drivers are fine. (To confirm injector operation, its easiest to measure the duty cycle (with capable multimeter) of the injector whilst running, to confirm its opening)
I've run the engine with the coil disconnected from the spark plug hanging out to view, with number 2 along side it to compare. Both sparked so I assume that meant they were ok and the ignitor channels as well.
I just did another test, plugging in spare injectors into the loom whilst the engine was running (injector just loose/not in fuel rail) and could get any to make a sound.
Could the ecu be purposely cutting cylinder 1 because of the code 54?
Edited by l6a6w6s6
Hmm, you have injection and spark, but only running on 5.
Maybe there is a big hole in the piston and no compression? :(
Sounds stupid, but are the plugs from the wiring harness connected to the correct number injector and number coil? Usually there is enough wire length for cylinders that are side by side to be put on back the front.
Edited by RB30-POWER
Ok so all of a sudden it just starts working. I knew the plug was getting pulse
but wasn't sure if the injector was firing or not (rtoo much vibratio and noise t hear or feel the click. So I took the cas out of the head but still plugged in, and rotated it with the ignition on. The number 1 injector definately clicked then. Even so I decided to change it back to the original one which I tested with some direct 12v, clicked on command as well. Switched them over and then it just fired up properly like nothing was ever wrong. Unbelievable but true, this is with the same initial components with what the problem started.
Car running well now except for a slight miss as it hits decent boost, but that's not to worry I'll put it on the dyno this week just to check the mixtures and what not. Thanks to everyone who posted with ideas your help is much appreciated. Special thanks to BHdave for some solid time going through everything with me on ICQ.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
