  • Replies 106
Hi Guys/Girls,
I've just dropped the stickers off at Works Auto, it's in Bentley, look up the website if you don't know where it is. Speak to either Simon or Ross and they will sell you a sticker for $2.
There is a long sticker in chrome for the back window, and a smaller one for the side windows, but you can put them anywhere else you like.
If for some reason you can't ever make it there then let me know and I'll find a way to get a sticker to you.
See'ya:burnout:
I have one prized space left
the bottom of my rear window is taken (with my HSV sticker), but the top of my rear windscreen is empty, so someone give me a good sales pitch why I should get this one and not a PPCC one (the other option) :)
you have your 45seconds
DJ, spin that shit!
Psiko,
Cause if you don't then I'm never giving you tyres again.
Cause if you don't then your not allowed on any more SAU cruises
Cause if you don't then we'll hurl rocks at your car.
Damn 45sconds is up, and I had so much more material.
They look good, and are suporting this forum, so "Just Do It".
See'ya:burnout:
Is works auto that one in bentley (of coarse u said that) but next door to BP in front of the shopping centre? Always wondered what that place was had all nice jap imports parked there just thought it was another one of those shops where u pick up a whole lot of useless jap crap u know speacial air freshners and snoopy handbrake covers etc now ive been reinformed - unless its not that one.
Everytime im at that BP its like attack of the clones theres always me and then 2 GTRs parked beside me - dont go in there anymore it shrinks my ego too much :)
Nizmo,
That is the place, although it does sell alot of rice crap, the two guys running the place are more into performance, so they can give you some good ideas of what to do with your car. They also do bodykits etc, so pop in and say hi, grab a sticker while your there.
See'ya:burnout:
I bought a sticker yesterday - and couldn't wait to get home to put it on! I still feel a bit weird about having "skylines australia" on my 180sx..... but I LOVE the sticker (i got the one with the red - 2 of them).
Thanks so much to the people who organised it!
Haha i'll buy a couple and put them on the company cars .....
so if you see a couple of govt plated cars driving around with skylines australia sticker on the back of them you know who did it *evil laugh* you'll also know who will be out of a job the next day!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
