  • Replies 53
Hi, Guys. Just a note of caution to all of you budding bucket chemists. You need to take care how you throw this stuff around, if any of you are thinking of mixing it outside the tank. The best way, I would think, would be to part fill your tank, add the carefully calculated amount of Toluene/other additive and then finish filling your tank with normal gasoline from the bowser.
Avoid chucking this stuff into buckets/drums or whatever. Keep it in a suitable container and pour it straight into the car.
If you must pre-mix, then do it outside (not even under a car port), well away from electrical appliances, including lights. Minimise the opening into the drum (i.e don't just slosh it into an open top container) and stand up-wind. To minimise your exposure, wear gloves (those red plasticky, rubber ones that come up over your wrists), preferably some sort of mask to protect from fumes and DEFINITELY wear goggles to protect your eyes from splashes. Do everything you can to minimise ignition sources. Bear in mind that any vapours will be heavy and tend to slump over the ground - so close the door into any building nearby (like your kitchen!) to prevent fumes drifting in. Bear in mind that ignition could occur some distance away and flash back to the drum/container. (So don't think you can let your mate smoke 10 metres away.)
If half of Perth is going to be sloshing this stuff around, we are bound to hear of some idiot getting burned. :D
Don't play with the stuff if you do not know what you are doing. These are chemicals with a significant fire risk. Just drive slower for a few weeks on whatever petrol you can get!
Cheers. ;)
Hi everyone Dr dangerous here!
Yes toluene is almost as dangerous as normal petrol, although petrol is far more volitile, has more toxic fumes and contains carcinogens.
So if you must use it then do so with as much care as fueling up your lawn mower. If fact people should take more care with their lawn mowers for future refference.
Toluene for the record is not carcinogenic. If someone wants to argue with me then I will respond with 'my dad can beat up your dad..'
Toluene is ok with the O2 sensors if the mixture is right for the tune. Running higher mixtures will result in unburnt fuel, the toluene component helps to keep O2 sensors clean thanks to higher exhaust temps, it's also a good solvent to clean things with.
What about this rotting fuel line bizzo I have been hearing about?
How hard is it to add in a couple of degrees on the CAS? just loosen bits off then swivel a tiny bit, then tighten? (with exact measuring taking place of course)
what ever you do use a timing light and its a good habit to scribe the positon of the cas before you start, as it will make it easy to reset it to the original time
I found resetting the ecu worked well, just let the car work it out for itself :) but that was when I just used to throw 4L ( 2 ice cram containers) in half a tank of fuel - it was all pretty technical stuff :)
Rev210 (aka DR Dangerous..lol would make a nice new nick) would you think it necessary to increase timing if you are doseing up your fuel to bring it back up to 98?
reseting ecu only changes the 'closed loop' map. It does not effect the ignition or fuel maps for power, otherwise you could mod things and not need a PFC or other programable ecu.
A manual advancing of the CAS will only 'shift' the timing map so to speak.
If the OEM ecu detects knock, it pulls timing, and I can 100% guarantee it does this at WOT, not just closed loop. Resetting the ecu, causes it to reset and relearn its timing maps
It does work, I have even seen the stock ecu relearn its power curve on a dyno after an ecu reset.
Of course resetting wont give you indefinate timing advance, nor will it directly add or remove fuel into maps, but it does allow the ecu to readjust to new fuel, or new driving style. So I dont see where you are coming from with the no need for aftermarket management theory.
Hi Steve,
I am pretty sure you will find the timing maps in a stock ecu are fixed. If you can show me a timing 3D graph Vs load before and after then I would agree with you. A power curve isn't idicative of the timing map.
Thats why the 'Lumpy ROM' for the R32's is really good as you can modify fully the timing Map in 3D.
Perhaps a tuner would like to and 2c?
the PFC can handle that. Go into 'settings' and then 'inj/ign' menu add advance on the fly as you need it and monitor the knock levels. The addtional advance you plug in on this menu needs to be redone everytime you restart the engine as it's temporary. So there is no danger of you forgetting once you are back with normal fuel and running to much advance. This tool is a fairly blunt instrument by my experience. I tend to change the map itself after writing down the original values.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
