  • Replies 59
Posted Images
Check ur connections, it might be loose. If it's not that, if u have a volt meter, see if ur voltmeter fluctuates. Is there anything that causes it? EG: hard acclerations, ur sound system too lound? Could be ur battery starting to die. Check that u have enough battery water too.
Cheers!
If you're using a H4, as ben said, it's already inside? But i don't see how. If you bought it from ben, and he didn't give u a set, then i think u should ask him for 1. If u bought ur kit from someone else and ur kit didn't come with a relay, then i guess u can make do without it. Different specifications.
ABout that flickering and stuff. You know the back of the ballast bracket how there's a bolt that goes through to hold it to the ballast box, well if that bolt touches metal surfaces will it short, could that be the prob?
Yeah that could very well be the prob! Imagine, if ur car is bumpy and ur ballast is jumping up and down, it occassionally touches the ground, and u get ur flickering. try padding it wit something, and try to secure ur ballast properly so that it dosen't shake/vibrate that much. =)
P/s: Pulp, have you found out the problem with the flickering ?
Oh sorry I was only asking in regards to the other guy who had the flickering problems ;) Thought that may have been something to look at. Man I haven't had a chance to install mine yet! Going to make up a bracket for the ballast boxes.
Oh okies... haha i'm gonna get mine installed tomorrow after my exams, problem is, i don't have a drill. :( So i've gotta go to some workshop to borrow their drill and drill the f**k out of my caps. :lol:
Dude, just head to WA salvage. I got my drill for $12.99 ages ago, and a box of about 20 drill bits for $4. They work fine on plastic, everything else and the drill bits arent that good, but for that money, cant complain
Got my hid installed, took 2 hrs, and am quite happy!! The only problem is... My lens is too dirty/oxidised!! The inside not the outside... and now my parkers really look oxidised. FUG. Back to the ol drawing board.
About the flickering that was happening the other night. I've checked all the connections and its all fine and I used cable ties to hold almost everything in place, so I don't think there's any short circuiting.. I then checked the battery water and noticed that it was very low - so I think it's that. Just topped up the water tonight
It only happened during one trip a few nights ago when the car was idle and when I was slowing down. Since then haven't come across it doing the same thing.. so hopefully it was just the water level in the battery. But will see how it goes now..
thanks everyone for trying to help :D
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
