  • Replies 143
Late start tho! Tired today (bad knees, 7 surgeries on them, very sore last night / today) but I'll be there 4 sure!
See you all there, looking forward to saying g'day and showing off my Stagea "Project Stealth Wagon" :)
Brendan
Damn it - got lost. Oh well, but it was good to meet a few of you. Should have taken down a phone #.
Just couldn't tromp the car hard enough due to it needing a retune, was a few cnrs behind up the Eagle rd, but ended up going between Stirling / Bridgewater 4 times, looking.....
Cruised thru Handorf then Echunga, Meadows etc, nice drive tho!
Major doh!
:( BW
AGGGHHHH I GOT LOST TOOOO!!!
i think u were behind me bwilkeson...u had the yellow headlighs?
we got 2 a turn off at mt lofty and i went left, n i ended up on greenhill rd, but there was no1 there! so i went bk up, still nothing, then drove up magil rd cos i heard som1 say 'magil' while i was standing there n nothing :(
I couldnt keep up cos my clutch is slipping.....:O sorry guys
hehehe, we got lost too! with oosh and driftR, we even got a lovely visit from the police force :P at Lobethal were we ended up trying to find the rest of the pack.
Luckily for us no defects or fines were issued on the night. :D
Edited by Richo
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
