does the din panel fit r32 gtst?? i heard it might not??
Should do, presuming its a standard sized DIN slot :(
The DIN panel is approximately 19cm x 6.5cm
Cheers,
Steve
  • Replies 58
Hi guys,
We have now sold out of the smoked face oil pressure gauges and will be offering Type B bundle with Air Fuel gauges instead of the Oil Pressure gauge as part of this bundle.
Cheers,
Steve
Hi mate, we advise measuring the space you want to use to fit them just to be sure. The DIN panel measures approximately 19 x 6.5cm.
Regards,
Steve
Hi guys,
Cheers,
Steve
When would you get more "oil pressure gauges" ?, as i have no use for a "Air Fuel gauge" of that type?
Hi Al, we have more oil pressure gauges on their way via air freight so they should be back in stock soon after we re-open on Monday January 9th.
Cheers,
Steve
Great!
At the moment i am still deciding between your $200 gauge set or the original $600 Defi DIN-gauge.
Is it possible to get 1xoil temp, 2xoil pressure?
Then use one of the oil pressure gauges to measure fuel pressure??
Al, no problem. You can pick 3 of the plain smoked face gauges of your choice as part of the bundle.
Regards,
Steve
Hey steve, great looking gauges for the price. I was wondering about the illumination, they look like they'd be trick at night but what about during the day? As in, do you hook up ignition and illumination so you can see the gauge during the day and illuminate when you turn on your lights or is the illumination and gauge a matter of on and off
Cheers Steve, keep up the great offers :rofl:
Edited by ellie
  • 1 month later...
Is this still available? interested in package B
Sure is :) and you will notice we are now offering these bundles at an even better price!
Cheers,
Steve
Interested in Package A,
still available?
if yes, i will come on friday probly to pick up,
cheers,
Edited by ZXFIRE
ZXFIRE: These packages are still available and we have plenty of stock ready for immediate pickup and dispatch.
Cheers,
Steve
Great!
Is there anything tricky about using the oil pressure for fuel pressure? If not, I'm going to buy 2 packages (6 gauges)
*thanks zxfire for linking me here.
Anyone fitted the DIN gauge holder in R33 GTS?
What is involved in hooking up the oil temp, oil press and water temp gauges?
Also, as someone else asked do they do a 'opening ceremony' similar to the real Defi BF gauges on startup?
Thanks.
Just a quick question Steve. Do these guages do the cool activation circular flash thingy when they turn on like the real defi guages do?
Hi mate, not these ones no.
Regards,
Steve
Hi mate, this is not something we have tried nor would encourage. Unfortunately we do not have any fuel pressure gauges available in the Autogauge range.
If you would like to place an order, please email our sales department for a quote on freight to the US before placing an order as postage values included on our website apply to Australian residents only.
Sales @ justjap.com
Regards,
Steve
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
