Hi,
As the title suggests I am having a little trouble with my tune on a rb25det with a gt30 bolted on. Mods are as follows:
all supporting fuel mods, pfc Pro, zaust cam gear 3' neg, 3 inch zaust etc etc etc... Oh yea, running 19.5 psi...
The A/F ratios are just below 12:1 but so close you could say 12:1...
after we got the fuel right we started to add timing, but once we hit about 245 kw she started to ping badly, Big Carl had the same setup and made 260 kw... I cant think why I am experiencing this pinging, possible reasons are:
bad fuel?
oil in the intake piping?
F*ck, I dont know :D
any ideas why I am experiencing this pinging? We did not get a chance to wind much timming into it due to the pinging...
Would it be better to add a little more fuel to allow for more timming?
Edited by GunMetalR33
https://www.sau.com.au/forums/topic/94779-gt30-low-mount-tune-results/
  • Replies 53
Posted Images
UPDATE:
Just spoke with my tuner, I was wrong about the A/F Ratio's. They are actually about 11.6:1 which is ritcher than I figured. Also on a power run it seems that the knock is happening at 6,000 rpm at full boost. Had a look at the map trace and I think we are only talking about 3 or so cells of timming that are causing the knock.
If I amend those ignition cells and the knock goes away is it safe to lean it off to say 12:1 and would this make much difference to the power produced? (I am not worried about the final figure on the dyno, I was just expecting more mid range than the tune currently produces).
Experiment with pulling 1 degree timing out when she starts to ping. Trace with the Map trace or you can do it easy with the settings -1 timing but that will pull one degree out everywhere and you dont want that.
Going from 11.6 to 12.0 is not going to make much difference at the wheels
Good luck
cheers,
Yea I have taken -1 out of the entire map just to see if 1 deg would make a difference and it did so now I just have to isolate to cells at around 6000 rpm causing the knock and take a degree out or two.
I would expect, leaning it out a little would make some difference...
i thought retarding the exhaust cam gear was more beneficial?
It might be retarded, now you have confussed me???? I know that it made a benifical difference when I put it on so I must have it right :(
Actually now that I think about it, it was neg 3 deg :P
are you referring to the lack of midrange problem re: injector lag time wrong? or something else. try a dyno run with the dump pipe / exhaust dropped off. see how the midrange compares. may find the exhaust is too restrictive
The lag time won't be an issue as you have tuned the car at the current setting.
With a similar setup i found about a 3rwkw loss dropping mixtures from 12.4 to 11.9 with no other changes.
Out of interest, what sort of response does it have? Any dyno sheet?
Just noticed you are running an rb25 exhaust housing. They are pretty small and may be restricting the flow, but on the up side improved response.
I thought the internal gate gt30 hybrids were using vg exhausts?
Arr, so I am not going to get to much power from leaning off then... The response is not bad. I get full boost (19 psi) at about 4000 rpm.
I will post the dyno sheet tomorrow...
Thanks for all the replies, Oh yea: I just changed the ignition cells that were causing the issues and it seems to have solved the knock issue...
Now I just need a little more power.
hmm what about the wastegate size? may be a bit small and overboost, which wasn't apparent on the dyno?
No over boost is happing cause the PFC tells me the max value for manifold pressure and it never gets higher than about 1.3 bar... Maybe 1.32 but the tune allows for a little over boost...
I'm running a GT30r with a VG30 exhaust housing, (.63 internally gated) and I will let you know how i go with the tune next week.
I'll have Nismo 550cc injectors.
Also, its bolted up on the stock manifold etc, pretty much the same setup.
I have a powerfc also.
man, 19psi? I that a stock bottom end? If so.. thats gonna kill it!
dont use octane booster unless you wanna change your plugs after using it.
If you cant get it working on PULP then there is a problem somewhere.
I'd start with the exhaust side of things.
Drop it and see what happens. You also need to find out the spec/rating of that turbo
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
