  • Replies 134
Am I too late ?
Also, does it come with the boss installed to screw in the temp probe ?
If it's does have the boss and I'm not too late, I'd like to get one please ( Skyline Bolt up 3" ).
Cheers, Scott.
Post updated, thanks for the quick payments guys, only half of you left to pay, also dont forget to tell me if you are getting the 3inch bolt on on normal one and your address when you pay, thanks!
I'm in for a 3" bolt on, is payment on monday too late? that's when I get paid.
hey mate, if you can pay on monday thats fine, ill send you the payment details now.
Update:
I have ordered the cats for the ten people (including me) who have paid already, as per the list in the first post.
They are still waiting to get the compliance cat from SydneyKid, so when that arrives they will make and send the bolt on cats, but they will send out the normal cats (non bolt on) straight away.l
I will send off a second order with the remaining people as soon as they all pay.
Update:
Im free tommorow from around morning till 4:30PM.
Possible for me to take my car in to get it installed as well as the dump pipe?
Maybe I can take my cat to use as a model? But I think mines 2.5"? Its the stock one.
Update:
Very hectic weekend, getting ready for Eastern Creek next weekend.
Picking up the sample cat tonight and I will send it to Magic tomorrow.
Bank transfer also will be done tonight for my DIY cat.
:( cheers ;)
Only just saw the thread, Can I still get one off you payment will be made today if I can!
Yep thats fine i am making a second order for those who could not pay as fast as the first lot.
I will pm u the payment details now :(
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
