I'm replacing the oil in a R32 Viscus LSD diff, since it wasn't delivered to australia they don't seem to list the type of oil required in the books in the auto parts stores. Can someone recommend a Castrol oil that would be suitable? I say Castrol because all the other fluids are castrol and I like to keep it in the family :P
Cheers
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/
If the oil isnt black and its still gold, dont worry about it, the oil that the japanese use in diffs as such is much thicker and better........but if its black yeh change it with what u think is necessary, aussie oil isnt as good.......but its easier to find then HKS diff oil or something like that
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1713579
Well the oil wont go black in a diff, cos theres nothing to contamniate it with, but it still might be 'worn out'.
You can safely use any GL5 oil that is rated for a differential. It does NOT have to specifically be for an LSD type diff, because the viscous unit is not affected by the oil. Cos you like castrol you can use;
Castrol EPX 80W90
Castrol Multitrax
Castrol SAF-XA (Synthetic)
Castrol Syntrax (Synthetic) <--- Recommend this one.
Cheers.
Edited by Busky2k
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1713956
Where did you get the idea that Japanese oil is better than Australian. That is not true.
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1713983
Castrol EPX 80W90
Castrol Multitrax
Cheers.
The oil in a diff CAN go black. If it has been punished it will become burnt, the more burnt it becomes, the more black it becomes.
As for Castrol oil - I would not touch the crap. I put Castrol oil in three seperate Skyline Diffs and all three developed a whining noise. One of those was my car and the whine got worse and worse until I changed it - for the third time. Castrol don't want to know anything about it because it is an Import.
I only ever recommend REDLINE Diff Oil. You should use a 90 or 140 grade. Places like Autobarn can get it for you or if you are in Brisbane, Thompson Spare Parts stock it on the shelf.
If you have to use Castrol, ONLY USE THE SYNTRAX AS SUGGESTED ABOVE. The top two listed will wreck your diff.
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1714014
Well not everyone wants to buy synthetic so yes, I suggested the mineral oils, although I would not use them myself.
If the diff oil is going black, it is most likely to be poor quality (ie lots of oxidising), poor sealing issues, or there is lots of wear happening!
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1719511
3lit3 if the oil is gone/punished,will you start hearing a clunk when engaging first or reverse?or does that just mean the diff is probably worn?
cheers
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1723603
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
