done a search and nothing...
story goes... ive picked up a rb25neodet but the turbo is full of oil as was the intercooler... ppl told me the car had rolled and engine oil had gone to the turbo and to the intercooler :angry: ok
but i dont like the look of all that oil sitting in the turbo when the time comes to run the car it will prolly blow a shitload of smoke and any remaining oil will burn and leave a film of carbon through the turbo and exhaust...
my questions are these:
1. how hard is it to pull apart a turbo i have access to an engineering shop (lathes and mills) wide range of hand tools (no surface/cylindrical grinders)
2. can you get a manual specifically on the turbo all the torque settings/ tolerances ect ect
3. whats involved in reconditioning it
4. i understand they use ball bearings because roller bearing give a up and down shaft play... what if i found a sutiable tapered roller bearing assembly??? thinking out loud they allow for minimal up and down aswell as in/out play if installed correctly
5. where can i pick up parts to do this myself i would also like to change the stock ceramic wheel to a steel one incase down the track i decide to wind the boost up and losing a exhaust wheel into the cat
p.s. its a stock rb25detneo turbo if that makes any difference, says nissan on the intake side
thanks fellas
Rick
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/
Have you considered the turbo, cooler etc was full of oil because the motor is stuffed?
i.e blowby?
It is a very common (and costly) mistake for people to rebuild there turbos only to refit the new one and suffer the same oil problems to find out it was never the turbo at fault.
The roll over story dont sound good either. The only way engine oil could of got to the cooler is if it was still running when upside down from the oil pouring out the breathers into the intake.
And if it was running upside down, the bottom end would not have liked it too much.
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1718807
you need a professional shop to do it.
Or specialist balancing machinery.
Its not a case of putting on wheels and it working.
Everything needs to be balanced 100% corectly cause @ 150,000rpm there isnt provision for something unbalanced and it wont last any length of time.
But turbo doesnt sound stuffed to me. More-so the motor side of it
simply put - dont try it at home
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1720840
ok
so if it isnt the turbo and it was this "blowby"... how can i tell if the engine is any good any quick test i can do.. how much would this cost to fix... and can someone explain blow by just to give me an understanding
the motor is still under warranty but since then ive cleaned it right up and looks like a different motor so it would be a shame to see it go
also... there was no oil through the intake piping (by memory will check 2nite) the dump pipe and zorst manifold were full of a oily soot dont know if that is normal though... the motor was bought and seen running (not by me) and the ppl i bought it from werent average joes, they have a pretty good sense of what they would buy...
Edited by Space Goat
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1721424
ok
the motor is still under warranty but since then ive cleaned it right upand looks like a different motor so it would be a shame to see it go
Get a compression test and leak_down test done. That will tell you if its stuffed or not. Not that expensive less than $100.
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1721454
Speaking about rebuilds,
what is the cheapest price for a rb25det rebuild?
I've heard figures ranging from 3-7. If I only get new forged pistons and gtr rods where does the other 2-5 grand go? This is for the bare minimum required for a rebuild.
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1721504
If the cars been sitting there upside down some time with oil dripping in via the turbo's oil return (as when the car turns upside down the chances are the oil return will pick up a bit of oil and feed it back to the turbo) then I have no doubt that the oil would seep past the seals and in to the comp and turbine housings.
Every turbo I've had I've primed it with oil via the oil return and sat the turbo upside down. Walk in over the next couple of days and I will see oil in the comp and turbine housings.
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1722929
hi
i dont think its blowby as there is oil in the intake side... and with blowby there wouldnt be oil in the intake side as it only suck through the zorst port..
thanks cubes for your input thats pretty logical thinking come to think of it the someone flipped their car they would turn it off climb out and wait for the cops, towies ect by the time they turned the car around it would be a good hour
im gonna get it rebuilt by a person who knows wat they are doing
thanks
Rick
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1722966
Pull the comp cover off. When putting it back on use some lock tight.
If the back plate is excessively oily/sludgy and not silver as it should the chances are the turbo is starting to get a little long in the tooth. If its only a bit of oil thats seeped through then clean it and don't worry about it. :)
If it is oil thats seeped through there will be oil in both the compressor cover and turbine housing.
While you are there place your ear really close to the turbo, spin the assembly really slowly listening for any crunchy sounds.
Edited by Cubes
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1723000
hi
umm... if you have blowby it will be all through your intake piping if its all stock and u have no catch can.
the exhaust side will just be whats sucked through and burnt as a result of the intake being filled with oil
https://www.sau.com.au/forums/topic/95039-turbo-rebuild/#findComment-1723321
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
