Hi, my car is a S1 R33 GTS25t and the BOV in question is a Blizt DD. After intalling the BOV when breaking into a shape corners the engine will stave of air and stall on me. I have try this a number of times and it still stall on me BTW the car is AUTO. I think it's the hose overheating or the ECU is not use to the BOV yet. I have reset the ecu and will test some more on the weekend. did anyone have any problem like this before? maybe because i'm not running a pod.
Also can anyone please attach a pic of the engine bay with apexi pod installed with stock AFM.
Thanks in advance.
atmo bov you have. atmo bov no worky. it vents air, the engine expects that air is still be there so it adds fuel / timing to suit however the air is not present so it runs too rich and stalls. fix use stock bov
dude, you can't fix it.
Well, actually you can. Either plumb back your BOV or put the stock one on.
Why would you bother putting a loud fully sik OMG!!!!111oneoneone!!!11 BOV on a auto anyway.
Do you drive around, foot flat, and taking it off the throttle quickly to make your BOV vent on purpose when there are some fully sic chiks around?
Let me guess, you're a poser?
hhmmm
This is why your Fully sic BOV is making your car stall. You run an AFM before the BOV, it measures air that is gonig into the motor and the ECU puts fuel and timing in to suit.. Use a Vent to ATMO BOV and it takes away this air and leaves the fuel behind..
And what do you know.. that fuel doesn't have that air anymore to burn, so it stalls, pops, farts, and carries on.
If you want to run a fully sic ATMO bov, get a powerfc d-jetro and run a MAF at the throttle body.
That'll make the chicks look....
oh and if your wondering why your getting a lot of smart assed answers...Next time, try using the SEARCH function, this topic has been covered about 34568938930295345 times, by people that have no idea about the car they drive. They think you just turn the key and the wheels go magically. And they also seem to think that if you install a Vent to atmo BOV all the chicks will line up and want to ride with you.
lol can't believe I typed all of that.
Edited by The Mafia
why does everyone say use the stock? If he wants the sound, he is entitled to it.
It's all about the setting of the BOV. I got a Greddy Type-S and my car doesn't stall at all! It's all about adjustment, tighten the spring and it should stop stalling, but don't tighten too tight otherwise it'll flutter and the BOV isn't actually doing its job.
The only side effect of an atmo BOV is that it'll be rich when the BOV vents, and you may get a bit of backfire, especially after letting off on hard throttle.. but being an auto, you won't get rich conditions on gear changes.
having said that, yeah, he should get flamed for not searching.
Any Tech feed back? thx
you got it within the first 8 words of the first reply
simply put, you wanna use an ATMO BOV... you'll need to purchase a SAF-c/PowerFC and have the thing tuned so that it wont spit the dummy
This can be found by searching and reading, trust me :blink:
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
