Well im in for the group buy, seems like u guys wanna go for the good stuff.
1km distance is more than enough i think, if yas get too far away or really get lost i suppose u can always whip out ur mobile.
As long as the clarity is good, then ill be a happy camper.
  • Replies 96
only prob with the above 1's, in a group buy situation...it'd be good to get those, but they come in 2's with the single charging dock...so you cant even get a set of 2, and give 1 to each paying member in the group buy if you know what i mean....
might just be easier to go with the 1's shan was talking about that come individually
what kind of accessories? is a cig ligher plug one of em? if they are PM me ill probably be in.
accessories available are:
VOX headset (so it broadcasts automatically when you speak) The CB is capable of VOX
Cigarette charger
Mains Charger
Protective case/belt clip
THe CB itself is 1.5W so its broadcast and reception quality is very good compared to the 0.5 and 1.0 watters. On the Mt Macedon cruise I was using one, and I was getting the rantings of Ash in the group of cars before ours (we went in groups maybe 2 to 3km apart). The others in my group couldn't get him.
Cigarette charger
Mains Charger
Sound good Shane, lets get the ball rolling.
yeah im interested in the single 1 from the thread that funky posted...the previous group buy....
dont get confused man, thats not a current group buy i dont think....but it may be do-able again if funky is interested...
although the dual unidens posted above look cool, they come as doubles with a single dock charger, so we cant really buy em and split them up between the paying members....
these things are cool on cruises though, so im interestd
ok, well lets start listing interest in here, so that if funky is gonna help us out, he can see that the interest is there
1. Abusd
2. Dezz
3. West
4. West
5. West
6. Ferni
7. Mavric
8. Saff_cossie
we're doin alright!
Edited by dezz
here's the prices for the units and the accessories providing you get 5 or more:
1.5W CB - $64.70
4 x Ni-MH Rechargeable Battery AAA 900mAh - $7
VOX Headset + Microphone - $10.70
Mains Charger - $10.70
Cigarette Charger - $10.70
Carry Pouch - $5.45
I recommend you get a mains charger if you don't have a AAA battery charger already as the cigarette charger I found gets in the way of the headset. Its only useful in emergencies.
Also if you want the items mailed to you it should be about $10. Seeing as you guys are all in melb, just organise to meet up with me at an event or monthly meet.
yeah but that ebay 1 doesnt look like it comes with all the stuff these do...just something to take note of :)
well if u buy it at $45 then just buy the charger for $10.70 extra
tell me whats cheaper?
or look at it this way... even if i end up paying 100 delivered for 2... thats still only $50 each... with the money u save from buying from JayCar u can buy the charger and a set of batteries
warranty biznitches :D ask the ebay dude if you get one.
and no the price is capped at quantities of 5. The accessories are cheaper if you get 10. You save an awesome 30 cents.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
