Problem: Recieving 1 email for every post in every thread that I am subscribed to.
Is it possible to recieve only 1 email for a new post in a subscribed thread (until I view that new post/thread) rather than receiving 14 new emails for 14 new posts all in the same thread all within 1hr.
I'm sure it was how I mentioned above with the old version of forum software but has been changed to this since the new forum software?
https://www.sau.com.au/forums/topic/95610-email-notifications/
absolutely sends me mad as well no wonder i have been grumpy lately.
Also it would be nice to have the topic of the thread as the topic of the email
Other threads about email subscription issues:
http://www.skylinesaustralia.com/forums/in...showtopic=89680
http://www.skylinesaustralia.com/forums/in...showtopic=87454
http://www.skylinesaustralia.com/forums/in...showtopic=82777
when subscribing to a topic you have the following options:
No Email Notification
This option will not send out any email notification but will retain the topic or forum in your subscriptions panel.
Delayed Emailed Notification
This option will send out a notification if a new topic or reply has been made and you're not active on the board.
Immediate Email Notification
This option will send out a notification immediately after a new topic or reply has been made regardless of your activity.
Daily Email Digest
This option will send out a daily digest showing all new replies or topics for that day
Weekly Email Digest
This option will send out a weekly digest showing all new replies or topics for that week
You can choose which of these it defaults to under your "Email Settings" in your control panel. At this moment in time, its one notification per reply, hopefully once I have the forum scripting sorted out I can make it collate replies.
also, I've made an alteration to the forum scripts that sends the thread title n the notification emails you recieve. I'm still testing it so any feedback is appreciated, esp ones where something's wrong.
please post about it here:
http://www.skylinesaustralia.com/forums/in...showtopic=96418
excellent thanks shan that is perfect.
Re the subscription options, the one from the old forum is not there.....ie notify me for the first reply to a topic I am subscribed to since my last vists
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
