Hey everyone, I bought a Malpassi Fuel Reg for my R33 GTST like 6 months ago, And never bothered to install, Now i have to the time to do it, and i've just noticed i have no instructional Guide for it, Can someone Email me a PDF copy of it please? to [email protected].
Also by looking at the Fuel Reg i see i might need a Adapter of some kind, Is this True? And if so could you's point me in the right direction of finding it or making it.
Thanks.
Shaan0r :P
https://www.sau.com.au/forums/topic/95635-malpassi-fuel-reg/
For the adaptor, see Steve at EFI Hardware (in Melbourne, Mitcham).
The Malpassi has 3 ports - the one underneath is the return to the fuel tank. The 2 on the sides, you can use either to receive fuel from the fuel rail. And then there's the little doover on top for a manifold pressure feed and the adjusting locknut beside it.
Do yourself a favor and just throw it in the bin. I would use it as a paper weight but its too lite. And if you really feel that you need it dont get rid of the standard FPR it does a nicer job of maintaining fuel pressure as is has a steel diaphram. Just place it after the return line from the standard FPR so it will only provide the extra pressure required. What do you need it for anyway?
Dont fool yourself, malpassi aren't that bad. I have seen them used by a lot of top end drag teams. I also use one myself and its working perfectly. (ideal for an RB25 when you dont want/need to go the whole hog and buy new injectors)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
