I'll dig out my old dyno sheet for you tonight, it doesn't have boost on it unfortunately, can't remember if it was running 12 or 14psi at the time and made 174 or so rwkw. It was all in by 4200 or so on mine.
It's also pretty obvious where the power starts on the graph as mine has the straight line followed by the big hump aswell.
  • Replies 101
Champ hyper drive are very good and you might get mor but it sounds to me like a safe tune
I have an auto r33 and found at lower boost i made more rwkw at190 @ 10 psi with a very healthy power band
james
hm.. 50degree IT... gonna be some reasonable correction there for sure so it'll be even a lower figure realistically speaking.
for a gcg hi-flo/17psi on rb20 now me thinking it should be a bit more when you think that 15psi on a rb25 nets you around the 250rwkw
The RB20DET needs BOOST! :)
I went from the rb20det making 164rwkw on 15psi to the rb30det making 176rwkw on 9psi.
Engine size doesn't affect power, head and turbo airflow is what makes power.
Push 18psi in to it and it will crack your 200rwkw goal.
Speak to Chris32 what he thinks of his old Remapped ECU done by Martin Donnon compared to the PFC he now runs.
If I remember correctly he said the mid range power increased quite a bit with the pfc.
With regards to boost tailing off... This will aways occur with a manual boost controller to some extent, a cheapish option is to head down to your local turbo rebuilder and pick up a new wastegate actuator, down in Adelaide ATS sell an adjustable actuator for ~$120. You can select the preset also, from memory its something like 8psi, 12psi, 14psi, 17psi etc.
Where did u end up mounting the resistor pack?
The joys of trouble shooting a car that isn't quite performing the way you want it to. :O
Sorry I have to ask... Does it actually make any boost in first? Being an auto would have an advantage as it will spool a little earlier.
Edited by Cubes
yeah does get boost in first, sometimes it shoots to like 1.7 bar for a millisecond which is kinda odd. Spins a bit at the end of first gear.
Installed resistor near the brake mastercylinder. Right in the corner of the engine bay. That should be ok yeah?
I can't just put 18psi in it can i? its only one of those 22$ boost controler maybe it would help with a better controler. I dono anywhere in perth that could sell actuators may have a look around.
Yeah Millar the Hoon they do a good job I have heard only good things and my car does run nice and is faster just thought i should be getting a bit more hp than it is.
4doorsleeper runs a new gen GCG highflow on his RB25DET AUTO, that made 220rwkw on I 'think' 14psi.
So say... 20psi.. Might get you close to that.. Maybe depends if you run in to detonation problems. BUT then you need to start looking at engine reliability.
Resistor location will be fine, up against the master cyl is a little better than above the turbo dump :)
Hows fuel economy with the GTR injectors?
Edited by Cubes
yeah fuel economy doesn't seems to bad but i haven't been driving it much only just got tune and been give it a bit of shit just to see wats its like a bit.
Ill need another tune if i want to run 20psi though won't I?
do you think maybe my dump pipe cause cause problems its just a open dump pipe no splitters.
Haha is yours near your exhaust? oh yeah wat you think about heat wraping cooler pipes cause they get prity hot. (the onethat goes past the fan.
tune already cost me 800 and the guy recons it made no difference when he put 18psi into it so it isn't worth doing really i supose. It is a safe tune atm so probly best to keep it safe.
May just get a shift kit and leave it at that, not worth throwing an more money into the car since its auto, and any other upgrade turbo would just cost too much
Do you have a boost gauge + do you service your car much + how long have you had it + can you use cam gears to boost earler
Autos are choice 4 every day car and shift kit should make a difference
i wounder about the condition of your engine and gearbox
but remember hp is not everything you also need driverbility aswell
James
Ahh well.. Thought about reselling the turbo?
Drop on a R34 (choice) or R33 Turbo and make approx the same power on less boost with less lag?
But it really depends if your figure is reading a little low or not as to whether the r34/r33 turbo would make the same power.
yeah brought the car stock a few months ago probaly about 6 months or something. Service it often do all the work myself, yeah have a defi boostgauge. I dono why i would get r33 turbo or r33 doubt that would help. Hyperdrive dyno isn't one of those dyno's that read high so it would be an acurate reading.
I have changed the gearbox oil but have not yet changed the filter as gona do that when i do the shift kit. Still have not yet decided on shift kit or not yet.
Well I have similar modded r32 auto to yours anton, except no GTR injectors (have a nismo FPR to up the ante on the injectors a little).. but a highflow rb25 turbo (not gcg i dont think)
I'm only running 12psi at the moment and a bit of a self tune on the SAFC but it doesn't seem too much throw you in your seat.. and I estimate only around 140-50rwkw at the moment.
In about 2 weeks I am getting mine tuned.. but realistically I think i'll be lucky to get 180-190rwkw @ 16psi. The same turbo made 230rwkw @ 16psi on gtrgeoff's old rb25. I'll let you know how it goes, but I just don't think the RB25 highflow on rb20 is a great match.
Edited by predator2
was that geoffs guy auto? keep me posted on what you get.
I also find that at the end of the revrange when it should change gear is sorts backfires and i tihnk its hitting the limiter and take a little while to change. Is this just the auto not being able to keep up? and wil a shif tkit help
Here you go, same turbo, different rb20
running 12psi, i remember now because i still had the stock injectors in it at this stage which is why the a/f ratio starts climbing at 6k, i added a couple of extra psi after i put 550's in.
Yeah, manual gearbox.
I had an HKS adjustable, but i can't see that being the whole of the problem. It was holding a consistant 12psi right through to the end of the run.
This was on the stock ecu aswell, i got an emanage later on to run the 550's.
I can't see the gearbox causing a difference of 500rpm in response, though it would effect overall power. What sort of exhaust? what size/and type of cat/ and how old is the cat? Have you tried dropping the exhaust by any chance?
the exhaust is 3inch no cat, no spliter in the dump pipe, and has 2 muffler although the rear muffler is pritty much useless as its bigger than 3inch so wouldn't be doing much. Maybe the dump pipe is a problem? or the other muffler in the middle of the car
The back fires are the fuel cut they are pops arnt they
that is y i turned my boost down to get FULL throtal and a much better power band
i have an eboost2 and i can use it very well
so i turned they boost down and the computer can handle the boost now
thus a good power band + a couple more hp
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
