WTF is up with my BOV!! i have 2!!
Guest | hype^ |
check this out guys!!
when i bought the car i thought it had a stock BOV on .. but today i saw a piece of metal with "blitz" on it.. under the air box
im like cool iv got sumthin thats blitz...
i take a closer look and its a F**kn bov!!!
some idiot but a blitz bov on the car under the airbox and left the stock 1 there!!
and coz the stock 1 is ferther back the blitz 1 doesnt even get to go off!! it aint loud at all..
u cant hear the bov properly when u just rev it on the spot! only a lil on changes!!
what the hell do i do??
i was thinking of swaping the blitz and stock bovs around so the blitz 1 is the 1 used first for better sound..
or maybe replace the stock 1 with the blitz and some how block the hole where the blitz 1 was off (iv got nfi how to block it!)
what do uz recon??? :P
https://www.sau.com.au/forums/topic/958-wtf-is-up-with-my-bov-i-have-2/
mine is right next to my intercooler, and if anyone on these boards has heard it, they will agree with me when i say it is BLOODY loud!!!!
My stock one just blocks up that piping..
see...
Guest | hype^ |
dam prank! nice position! - my blitz is right under the airbox :P iv got no idea why they put it there.. but it should sound better after i remove the airbox and get a filter ;)
prank.. the problem with mine was that the stock was not blocked off..
so the air was filtering through the stock 1 and didnt have a chance to get to the blitz.
i fixed it today..;)
i but a piece of metal between the piping and the stock valve..
now he air goes straight to the blitz bov!
sounds nice!!!
but i need more boost and a POD filter and exhaust ;) to make it sound louder:uh-huh: :D;)
yeah. its VERY loud there... if i hit boost hard through any tunnels (spesh the harbour tunnel) it is seriously deafening. My whole front bar shakes when it goes off.
Yeah, i luuuurve my DTMS!! :P:D (thanks too).
JiMb0 experienced my bov at low boost last w/end. ;)
Guest | hype^ |
YEH PRANK!!
was i impressed or what!!!
did i hear u right in saying that it was only 2pound!??
that thing was loud as hell!!
:uh-huh:
i like the way u pulled right up next to my window with the wheel.. :lol:
and i got laughted at by prank's gf when i showed him mine,!
i cant believe its the same valve!!!:eek:
that was Bec 2. :) I have 2 becs, my gf and my other bec (a good friend) - that was my friend Bec, not my gf.... it gets confusing.
yeah, when i lifted off it had only hit 2psi. :) or thereabouts.
GTR80Y, i need to angle the valve upward!! ;)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
