WTF is up with my BOV!! i have 2!!
Guest | hype^ |
check this out guys!!
when i bought the car i thought it had a stock BOV on .. but today i saw a piece of metal with "blitz" on it.. under the air box
im like cool iv got sumthin thats blitz...
i take a closer look and its a F**kn bov!!!
some idiot but a blitz bov on the car under the airbox and left the stock 1 there!!
and coz the stock 1 is ferther back the blitz 1 doesnt even get to go off!! it aint loud at all..
u cant hear the bov properly when u just rev it on the spot! only a lil on changes!!
what the hell do i do??
i was thinking of swaping the blitz and stock bovs around so the blitz 1 is the 1 used first for better sound..
or maybe replace the stock 1 with the blitz and some how block the hole where the blitz 1 was off (iv got nfi how to block it!)
what do uz recon??? :P
https://www.sau.com.au/forums/topic/958-wtf-is-up-with-my-bov-i-have-2/
mine is right next to my intercooler, and if anyone on these boards has heard it, they will agree with me when i say it is BLOODY loud!!!!
My stock one just blocks up that piping..
see...
Guest | hype^ |
dam prank! nice position! - my blitz is right under the airbox :P iv got no idea why they put it there.. but it should sound better after i remove the airbox and get a filter ;)
prank.. the problem with mine was that the stock was not blocked off..
so the air was filtering through the stock 1 and didnt have a chance to get to the blitz.
i fixed it today..;)
i but a piece of metal between the piping and the stock valve..
now he air goes straight to the blitz bov!
sounds nice!!!
but i need more boost and a POD filter and exhaust ;) to make it sound louder:uh-huh: :D;)
yeah. its VERY loud there... if i hit boost hard through any tunnels (spesh the harbour tunnel) it is seriously deafening. My whole front bar shakes when it goes off.
Yeah, i luuuurve my DTMS!! :P:D (thanks too).
JiMb0 experienced my bov at low boost last w/end. ;)
Guest | hype^ |
YEH PRANK!!
was i impressed or what!!!
did i hear u right in saying that it was only 2pound!??
that thing was loud as hell!!
:uh-huh:
i like the way u pulled right up next to my window with the wheel.. :lol:
and i got laughted at by prank's gf when i showed him mine,!
i cant believe its the same valve!!!:eek:
that was Bec 2. :) I have 2 becs, my gf and my other bec (a good friend) - that was my friend Bec, not my gf.... it gets confusing.
yeah, when i lifted off it had only hit 2psi. :) or thereabouts.
GTR80Y, i need to angle the valve upward!! ;)
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
