Shipping Methods For Larger Items Japan -> Aus
hey,
I buy alot of stuff from japan, as i find it so much cheaper than australia. I have a nice person in japan that does the bidding and all the other stuff for me.
Thou he doesnt like buying big items as he says its alot of bs to ship ahaha ;)
I was just after some info on what methods you can uses to ship stuff like Car seats to Australia, Maybe some website with pricers and time taken (i dont mind putting it on a boat if its cheaper than air)
Basicly i wanna do all the work, so the buyer basicly just fills in a form and sends the item to me :D as i really want some racing seats and i find paying $1000 + for 1 seat is a rip off when they sell Good second hand bridge and reacor seats for around $300 in japan
Any info would be very helpful, even if the website issit in english.
Thanks Michael :P:P (cool face :) )
  • 4 weeks later...
  • Replies 45
the limits for japan post are listed on their english website (I provided this link on a thread earlier this week - and it is easily google-able). Show that to your bidder - seats should fit under their guidelines. Most of us who provide parts don't do anything that can't be shipped via EMS - because your bidder is correct, it's a pain in the arse.
  • 1 month later...
remember australia gets stooged with its max sizes though. 2m total not 3m and 20kg not 30kg.
My mate has a recaro reclinable in his room... no matter how I measure it, its always just over max size which is 3m (this is unpacked and not inluding seat rail) let alone the smaller aus max size which is 2m...
drift007 - did you dismantle the seat or am I missing something?
Edited by Streeter
I must be measuring it incorrectly or need to fold it a certain way.
Ive sent over 300 packages to Aus now. Im pretty sure Ive got the formula right. :D
Ive had the post office call me a number of times about packages being over sized and they were alot smaller than a seat too.
with the spoiler if the other dimensions are small enough it will be ok. eg very thin and not very thick (front to back) a seat is pretty chunky in all directions though.
If you guys can let me know how you are doing it Im all ears as it means more export opportunities :O
by seamail its the same size limits. i used to send bride seats by ems and have sent recaros as well. its a pain in the ass though as you can box them. if you box them theyre over. a pooload of bubblewrap plus big plastic bags them a truckload of sticky tape and you can send them. need to recline the seat completely flat though. seats weigh about 14kgs from memory and the postie that comes to my house to pick the stuff up has a good way of measuring which is faster than measuring every side. first measure the length from bottom to top, then measure around the package. add the 2 together and if its under 3meters your ok.
If they can be laid flat, or near enough - then you shouldn't have issues with dimensions - bubble wrap 'em!
I get exhaust parts (several items, inc piping) sent from australia this way - boxed they would be over the limit, but they just bubble wrap them as is
if you are 'crafty' you could make up a custom box (ie: with no, or little, unused volume) - but I think the wrap should be good enough.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
