Place for a service?
Guest Cacophony
Hi dudes.
New to the Skyline scene - so was wondering where I can go to get a good service?
I live in the western suburbs, so don't want to go down to Morphett Vale to get it serviced through the importer I bought it from. They charge about $160 though.
Any recommendations, and prices?
Oh yeah, what should I expect done for a new service (what do I need done?)
Cheers
https://www.sau.com.au/forums/topic/9590-place-for-a-service/
I would recomend Tilbrooks as a good place to go. Its not going to be cheap to get a good service. You are probably looking for new filters, plugs (platinum $150 ish) and good oil. When I had my first service it also included a few modifications (Power FC, Bleed valve, dyno tune and reporgramming the FC) and cost close to $1000. [The results were worth it though]
yeah everyone likes tilbrooks ... their results speak for themselves ... but if ure after something a bit cheaper ... try pvp imports ... they just did a standard tune for me and only cost me 110 bucks ... changed the oil and filter and check the rest of the car out ... i highly recommend them if u're not after a performance tune!! :wave:
Manta Racing 8234 8688
Deacon ave , Richmond
Had a few other things done to my car like replaced front pads
with bendix ultimates and flushed whole braking system and
replaced two iridium plugs ( bought six iridiums of my own but two were the wrong size) plus a major service came to around
the $500 mark.
It was choice either between tilbrooks or manta racing and I
choose manta. Its up to you who you take it to, both have excellent reputation, both know skylines and both you can trust
  • 1 month later...
I just clicked over 100k. :D
Can anyone give me the part numbers of the belt and plugs for a bog stock 95 R33. Also the best gapping for the plugs.
I dont think I can get to Tilbrooks or Manta in a hurry so I may just go local. What about RPM or Turbo Tune?
Cheers
Paul
Cheers
Paul
Well there has been great debate over rpm and others on nissansilvia.com, there are so many stories flying around about bad and good things...
never heard any stories bout manta ever...
Tilbrooks have a strong rep for quality work.
But if u want a job done properly, do it yaself. (if u know how that is)
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
