hey just a quick question.. i've got a r33 GtsT.. when i'm driving it pulls boost it won't go, it feels like it's holding back... on the boost guage it saying i'm on boost.. but yeah it doesn't go it's like it's lagging.. BUT when i turn my car off then on again, it work's normal it pulls boost then goes good... it only happens sometimes though.. any ideas??? i've checked all hte piping and vaccum it's all good... but yeah does anyone have this sort of problems??
https://www.sau.com.au/forums/topic/96188-boost-problems/
disconnect the battery .. for about 1 hour.. then reconnect see if its still there.. (this is just to reset the ECU) assuming ur running a factory unit.. if this fixes ur problem buy another computer if its manual i have a TIAL ecu to suit a manual series 1 GTST from my old car.. no speed cut no boost cut supports bigger inj as well let me know if interested..
https://www.sau.com.au/forums/topic/96188-boost-problems/#findComment-1744870
  MR SLY said:
can i dissconneted it for more then an hour?? like take it out at night then connect it back in the morning
a hour is plenty but u can leave off over night, does sound like a computer problem or a electronic part, may be a idea to have a inviro purge & a on car injection clean done, could be some thing as simple as dirty TPS & may just need to have a clean, worth a try... :P
https://www.sau.com.au/forums/topic/96188-boost-problems/#findComment-1745337
turbo is fine... still pulling boost....
update.. theres' oil in the last cylinder... and spark plug was BLACK AS!! got new ones and cleaned the oil away... works BEAUTIFUL!!
5 days later... it happened again.. so i checked if there was oil in the cylinder again.. there's none so i cleaned the ends of the spark plugs. now it works good again..!! what the!! again when it did happen, i turn my car off then on again.. it worked normal again..
can't figure it out
https://www.sau.com.au/forums/topic/96188-boost-problems/#findComment-1755578
i have a similar problem with my gtir, what it is with mine, is my afm on its way out, and if for instance i take off at the lights and load it up, it sends the computer into a failsafe mode, limiting boost to 7psi, and making it run rich as, im unsure if skylines have the same thing in there computers.
https://www.sau.com.au/forums/topic/96188-boost-problems/#findComment-1763132
One oily plug :P
How'd that oil get there? that's the question..
Was the plug oily or just real sooty from running rich?
If it was oily I'd be doing a compression test straight away, also I'd be driving it gently until you find the problem just in case it's a mechanical prob and not ecu or tune related ie: cracked or sticking ring or a problem with your valves.
If it's sooty from running rich and all other cylinders are fine check that injector then valves.
One oily plug is pretty scary imho.
Keep checking that plug see if it oils up again
Goodluck.
https://www.sau.com.au/forums/topic/96188-boost-problems/#findComment-1763323
but everytime i undo and check the spark plug.. i works good for about 5 days ish.. then i happends again.. i've just changed hte spark plugs... there's no oil in the cylinder..
nathmacca.. it does hit 7 psi...... i think i might change it.. thanks man.. but if anyone has other solution please let me know
https://www.sau.com.au/forums/topic/96188-boost-problems/#findComment-1766710
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
