Item:T04E turbo with garret internals
Item Condition:BRAND NEW!!
Reason for Selling: Selling my skyline
Price and Payment Conditions:$700ono
Extra Info:Specs:
OIL cooled 57 trim front wheel in .60A/R compressor cover housing.
.64A/R rear exhaust housing with internal wastegate actuator (adjustable boost pressure on the springs.
T04E internals from Garret with T3 rear housing
Contact Details: 0401427455 or PM me
Edited by Jsikalias
dude, i'm quite interested
Would it be a straight fit on r33.
Would you know what are the gains power wise with the front mount and boost controller.
Also is ther any shaft play or any other issues with the turbo?
By the way im in melb as well
with a stock ecu u will gain 210rwkw @10psi it is a straight bolt on its brand new no shaft play what so ever i havnt had the chance to put it on my skyline...
Edited by Jsikalias
i know some one who mad 240rwkw with one on 19psi
brought it on ebay for like 700 brand new or something stupid
but he rebuilt it once and then it blew up again, now looking for a new turbo
also no good for rb20, wont hit boost till after 5000rpm
Edited by nemz
hey buddy,
i cant assist u in fitting the turbo but i can reccomend u a turbo fitter its will roughly cost 600 with 3 inch downpipe or id say 300 if u alredy have a downpipe if u wonna u can come have a look at it urself today... just give me a call
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
