I need to know if any of the aftermarket torque split controllers operate without the need of the factory g-sensors.
Basically my g-sensor appears to be stuffed and there is bugger-all hope of finding a replacement one, so I am wondering if there is a controller that does away with the g-sensor altogether (r32 GTR) ??
Any help appreciated, am getting quite desperate now as I have to sell the car.
Thanks, Josh.
https://www.sau.com.au/forums/topic/96878-torque-split-controllers/
Nissan will have the sensors, as will most wreckers that have 32GTR's. They probably cost a fortune though.
I guess with a torque controller you could lock it into 50/50, but you will quickly boil the fluid and stuff the clutch packs in the transfer case... dont think anyone would want to buy it when it rips a 500m burnout down the street without the front wheels driving.
thanks fellas, you wouldn't believe it but I got one today! I've been trying to find one for weeks and this guy had THREE, my little bro tracked him down through word of mouth. no wreckers have them and nissan charge an insane amount for them (don't want to say how much as it might ruin it for others). Woohoo!
i think the hks one replaces the whole thing. about $1000 but.
it actually uses it. you have to plug it into the ATTESSA comp. SO you can still manually change it but you can also go into normal mode.
If you can find it second hand, as they no longer make them. Anyone got one?
HKS don't make them, but HKS kansai do. if you want charlie pm me and i'll grab one for you.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
