hi guy,
i currently own a 94 R33 gtst. and am (was) aiming for around 250rwkw. i currently have 225rwkw@ 15psi using a claimed 450hp T04 with PFC, 550cc Z32 ect ect... engine is unopened.
now the problem i have is that if i try to run more boost the knock levels start to increase... af/r are perfect 11.9 to 12.1 but is not making much more power on higher boost setting...
i still believe the turbo can reach my goals.... but am now starting to wonder what else could be holding me back???? intercooler, exhuast, manifolds ????????
what do you guys think???
Edited by skyman
https://www.sau.com.au/forums/topic/96904-want-more-power/
If it knocks due to pre-detination, could it be that the air in the chambers is too hot?
Do you have ajustable cam gears, and have you adjusted the timing when the PFC was done? I recken you might be able to squeeze a bit more out with cam-gear adjustment or something along those lines.
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1757804
I would say a quick set of tomie cams and forget the cam gears...
Thats what i am doing.... Found cam gears are hard to get right and found limited gains/loses....
wat power gains did you get from your cams??? where you able to run more boost??
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758124
I think you are pushing too much power with standard internals
240rwkw-250rwkw max with standard internals
plenium and do you hav a heat sheild and cai
mabe thremo fans
try 100ron and new tune as well
do you want power and or drivability
do you have a fuel pump and reg
james
Edited by Miller the hoon
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758132
Remember running thermo fans can be a pain...
Yes it creases less drag on the engine.... But when the fans kick in it puts extra strain on the alternator... So its it really worth it???
I did have a thermo fan on the hr31 only due to the lack of room after i did an engine exchange...
But found the temp to vary heaps and on a really hot day with the a/c on the thermo fan could not cope...
It was on almost all the time....
Id be checking out your intake temp and buying a set of cams.... 256 tomie's will do the job... Also a cai will help if you have a pod... Remember the colder the air goes in the colder it comes out....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758144
mabe thremo fans
james
my aim is 250 so hoping internal will hold
plenium is standard and standard clutch fan, i have all standard heat shelds over the turbo and a good cold air intake system, i also have all suporting mods including pump and reg
and james i want both power and drivability dont we all!!!
thanks for the reply
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758154
Would a lightend flywheel do anything to power out put and clutch
any sliping
and last i can think of without doing internals is homing and porting your exhaust manifold or go after market 1
james
not sure if if a lightend flywheel does anything for power??? clutch isnt slipping
ill try to find someone to test my cooler, hoping that will be the problem.
if not ill might have to look into porting, manifolds and or cams
cheers
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758212
stock internals should be fine upto around 280rwkw, he certainlty wont be at any restriction of the plenum or intake at 225rwkw thats for sure. you can check to see if your loosing pressure by recording boost at the turbo outlet and just before the plenum to see if your dropping pressure. boost doesn't make power, airflow does. upping boost will only amplify your problem, it will add more heat. more heat = bad. drop the exhaust on a dyno run and see how much you make. if you make lots more (which im guessing you will) then you need to look into a 3.5" exhaust and a split dump system and big mouth cat as well will most likely help
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758213
if i can recall i have around 1.5 to 2 psi pres drop. will try the things you have mentions next week....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758233
paulr33 if it is the exhaust how much are we talking about
i thorght 3'' with hiflow cat was good to 300rwkws
and skyman wat did your tuner say wat would he recomend
and wat ebc is it on the pfc and are they a good bc
james
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758236
james
turners not sure but thinks the turbo may be out of flow?
not using electronic one just a cheep daul stage one which has been holding nice steady boost for 3 years now....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758256
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
