It could also be argued that that power figure looks a tad optimistic for an automatic RB25DET with the mods you have listed.
I thought my graph was optimistic until I saw this thread.
3 inch turbo back (stock cat)
FMIC
EBC
Pod
on Auto R33 GTS-T
It gave me 190+ (192 I think) but timing was all out so the setting on the EBC was put back a tad.
I'm contemplating a SAFC2 and I hope it will give me 195+.
  • Replies 75
This is an interesting thread
Security: Lets not mislead people into thinking that 50rwkw gains are achievable through the use of an S-AFC, especially on a car like yours that is virtually stock because they arent - end of story.
The ONLY way that you could find that much more power is if your car was running like absolute shite beforehand. The gain is not soley attritbuted to your S-AFC.
I'm thinking that his base timing was way off. Majorly retarded.
That's where the gains were had, I'm guessing.
Can someone explain how the timing or "base timing" as mentioned above can be changed? Last tune, only the SAFC was touched, nothing about timing at all - just wondering if this would help me squeeze past 200rwkw (only out by 5.4rwkw at the mo.)
I think the only way to do it properly is a replacement or piggyback ECU.
Base timing can be checked with a timing light.
It is adjusted by turning the CAS.
hmmmm picture's would help ay...
I have 255rwhp in an auto and you cant compare it to a manual
and 50rwkws could be gain if it was running like shit on 92 oct
and serviced air leaks fixxed 98oct and a border line good tune close to blow up
sit am wondering the psi run
turbo mabe hiflowed
james
well Nick, if you read my post properly it says he played with my timing also.
apparently my timing was off to begin with.
he advanced it half way through the tune when it reached around 168kw and it jumped to 184kw.
my point of this thread is that he actually picked this up. not only did he tune my safc, he also fixed my timing problem. its for that reason i thought i had to post this thread... he definately knows his cars.
CAS = ?
Sorry about the questions, just interested to know. Autos are very limited in what you can do to tune them, especially in the R34 where the stock ECU is quite stubborn :(
and just as a direct reply to your post.. 50kw is 50kw.
if the dyno was reading high then it doesnt matter does it?
my base figure would've just been lower also which still doesnt change a 50kw gain.
and ive also said that he played with timing and allowed me to close the gaps on my spark plugs.
tell me another tuner that would allow you to do these things and give the same power output for the same price (it cost me $200)
Great, im really happy for you, but perhaps you didnt read my post. I was making a general statement and hoping you would post your before dyno sheet and or clarify specifics of what hitman fixed up to bring your power up (which you have now done)
Dont get me wrong, its a great gain, but for the 3rd time, i was simply saying it is always a good idea to confirm for everyone what was going wrong before so everyone understands where you made up the 50rwkw so people dont incorrectly assume that if they go and fit an S-AFC they will get these sorts of gains.
Either way, it looks good, and your car should be a different car now :(
any shop will be able to do it considering theyve got a timing light.
I havent seen a shop that doesn't have at least one timing light
Timing on rb25's should be set at 15+or-2 degrees at 650 rpm .
What was your timing set at before ? It can make a lot of difference .If retarded it wont have any power , if advanced to much it may ping ( knock ) and you may blow it up .
I dont doupt the 50 kw increase if your timing was way out , but the power your car is making is fat to optimistic in my opinion . As i said before its an auto and you have the aid of the torque converter and second gear .
A good way to find out the true power that your car is making , take it to wsid and see what your terminal speed is , thats a very good indication of your average power .
im pretty sure my timing was off.
i posted a dyno graph showing the before and after curve.
so just to clarify, i got 147 on 3" turbo back, fmic, pod and 12psi
with retarded timing (i THINK it was sitting a few degrees under stock).
if my timing was spot on then im guessing i would've made around 160kw as my base. but you cant really tell.
also another thing i'd like to add is he said that sometimes the knock sensor on the safc screws with the timing, if the knock is high then somehow it will retard timing so he advised me to disconnect it.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
