i need the screws for the spak plug cover and coils, do you have any spare ?
Ariel
hey ariel nice to speak to you again so soon i have the screws pop past one day this week and grab them.They are the small allen key ones your after?
I also got the coil monts and bolts if you want them to.
they can be yours free for being a nice bloke lol :)
talk soon
  • Replies 91
they can be yours free for being a nice bloke lol :D
talk soon
no worries, pm your no again and i will come past some time during the week. thanks
hi wayne
After reading above post i am wondering if my money has been sent to you in vain ,you said that you were posting injector rail injectors loom and balancer last week , having recieved a parcel from my inlaws from kiama that was sent monday and arived today i carnt but wonder what has happened to mine . I was also curious that items were not marked as sold. I amstill interested in head as per early post that you have not responded to .Even knowing that you have been very active on site.
Can you send me details of time post office and registerd post details so that i am able to start investigation from my end .
I would like you to RING me so we can sort this out before may when i will be down there for a wedding .
Peter Bourke
25 belvedere crt
chambers flat
Qld 4133 0402056274 0732971572
wake up buddy youll get your stuff i aint no rip off merchant.
Its funny a few guys dont get there gear on time and theres a big comotion but you never see all the guys standing up that got theres and are happy adding comments lol.
wayne
Spoke to your mum fri night she was going to find reg post number and send it to me the post office here in qld carnt do any thing until i get a number ,have contacted barracks heights post office but they carnt find any parcels from sherwood to bourke going to qld
peter bourke 0402056276
so what are you trying to say man?
I will find the registered post number and send it through.
Better still i will scan a copy of my registered post slip and post it up on the forum as there is another guy on the same sheet aswell thats still waitin.
guys, please don't get too carried away as yet, i am sure that wayne will respond and chase them up for us. it isn't the easiest time of year with all the holidays etc. over christmas
dondesoto, i have edited your post to remove wayne's details if anyone wants them they should contact you via pm.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
