hi guys
i'm still learning about these cars and i'm having some problems with my PFC. my knock sensor light (engine light) will come on from time to time when i'm boosting it, also comes on if i drop the clutch at hi rpm from standing still. when i went back to the guys who installed it they said it was fine. i have since spoken to another mechanic who said that its been set up wrong and i should not get the light on at all if is tuned properly.....so now i'm very confused.
My car is a series 1.5 R33 GTST it has the following mods;
air filter
3inch turbo back exhaust
front mount cooler
Walbro fuel pump (second mechanic said i need fuel reg as well)
turbo smart bleed valve set at 13.5psi (but doesn't hold it)
and of course a PFC
the car made a 182RWK (i was told by the guys who tuned the PFC that it will make more (around 200) once i get proper boost controller that will hold the boost pressure)
also i'm running a standard turbo
Can some1 plze me help..........i'm very confused and i don't want to kill my car
cheers guys
https://www.sau.com.au/forums/topic/97201-need-help-with-pfc-please/
13.5psi will fry the turbo. best to turn it down to about 11-12psi at the max. it wont make any more power at 13.5psi but it will make stacks more heat. the fuel pump's flow ratings are rated at 15volts and your skyline (assuming stock wiring only runs 14volts, or even 13) so it wont be flowing at the rating the pump is rated at, so be careful there.
the engine warning light will come on for 3 different reasons. in summary airflow meter, injector max, and knock over 60. the powerfc faq covers all 3 and how to diag / test for which one you are seeing, i suggest you read this and do some quick tests to find if in fact the warning you are seeing is a knock high warning or the other warnings
http://members.dodo.com.au/paul/
Documents -> PowerFC FAQ
hhmm... the knock sensor light is coming on hey. 3 flashes?
Have you ever considered that THE CAR MAY BE KNOCKING?
"Guys, I coated my floor with grease, and now I keep slipping over. Why could that be?"
Take it to a decent mechanic and get it tuned properly at 11psi - 12psi before you kill your turbo and motor.
Until then, DON'T hammer your car. You WILL kill it.
i got told by unique motor sports in castle hill the light comes on because the power fc is set up to have the apexi boost controller and if you dont the computer wont be reading right so go through and turn the boost of of the ecu and it wont turn on i havent done this yet but its what i was told
Just a side question - my car has flashed the engine light near 5600rpm when I hit the rev limiter. I have the rev limit set to that at the moment. Does it ever flash if you hit rev limit? Knock on the controller was less than 40 peak when this happened.
Set the rev limit low as I haven't had a tune yet
Cheers
Edited by benl1981
The light also flashes when your injectors max out. This is at 0.5 sec intervulls (vs 0.1 sec for knocking). When my car was getting rd tuned my injectors were maxing out at 6500rpm (9:1 afr will do that)
I'll finish the Power FC manual traslation over the holidays, and give it to paulr33 to host (if he wants).
Engine light will only flash if (any) of the following 3 items occur
airflow meter max out - reads 5.0volts
injectors duty max out - 98%
knock level too high - default is 60 at any one time
Nothing else that I know of will cause the engine light to flash in the PowerFC.
Bounce off the rev limiter all you like, it wont make the engine light flash.
I believe the car won't start if you have boost control kit enabled and aren't actaully using it / don't have it plugged in but in may in fact have the engine light permenantly on (always) if its activated and not being plugged in
well, running almost 1 bar of boost on a stock turbo on a "tuned" powerfc, I can say its got a 70% chance of knocking.
The other 30% I can bet the AFM is maxing out due to the stupid amount of boost and airflow ripping through it. At 210rwkw (12psi), my injector duty cycle never went above 80%, but the AFM maxed at 6500rpm many many times. (rev limiter was at 7200)
Thank god I have an ace tuner.
And I will say again; after 12 months of 210rwkw, and a fair bit of "spirited" driving, compression tests came back at 169psi accross all cylinders, with 2% leak down.
Oh, and Paul is right, if the boost control kit is NOT installed (or not functioning), and it's turned on, the car won't start. (most likely to prevent an overboosting disaster).
Edited by The Mafia
u forgot one basic thing!
TIMING! ADVANCE TIMING IF NOT TUNNED PROPERLY WILL GIVE U KNOCK!
IF IT PINGS WHEN JUST ABOVE 0- ON YOUR GAUGE THEN CHANCES ARE TIMING !
but i could be wrong...evil laugh bbbwwaahhhhhhhhhhhhh..
okay my 2cents worth
or coil packs might be failing!
the powerfc faq gives complete information on how to debug each of the "engine" flash symptoms. im well aware of knock and how its timing related, the guide states this also
well im glad u can read but i was offering advice not to you but to the person that asked it. :P
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
