Item: Blitz Racing 2 piece lightweight rims.
Item Condition: The rims are 2nd hand. They have a few marks on them, a little gutter rash. 1 rim has been repaired on the inside edge. Repair was done by a reputable wheel shop in brisbane, before I got them. Have been balanced also.
Reason for Selling: Getting another set of rims.
Price and Payment Conditions: $650 ono. May send interstate, but buyer pays shipping costs.
Extra Info: Fronts are 17 x 7.5 with a 45mm offset. rears are 17 x 8 with a 45 offset. They were fitted to an R32 GTS-T. Looked good on a Black 32.
Contact Details: Scott. 0400 975 334. Or Email Scott.Bailey @Vision-bio.com
Pics coming tonight.
The emails I recieved this morning, have now been replied too.
Feel free to come and have a look.
Also, Reasonable offers will be accepted.
The Tyres are ok. About 3mm depth I'm guessing. One has a worn outer edge. 2 are Bridgestone Potenza's, the other two I'l check for you. Enough tread to last a while, if you don't rip it up everywhere.
Simon,
I've email a pic to you.
hey buddy any cracks on the back???
the first photo of the single wheel looks like it needs work on it therefore from what i see is 2 buckles on the front where the valve hole is.
would you take 400???
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
