That's pretty normal for an r32 stock turbo, especially without a boostcontroller (just using the stock actuator alone). If you have a look in the forced induction section, people have posted responses on how to solve this problem.
Personally, i'm using the jaycar iebc. It has allowed me to sustain 10-11psi all the way to the redline, and build boost much quicker too.
Mine doesnt drop off... then again it doesnt reall come on till 5,000 (HKS 2535) :)
Its just because its the standard turbo. Nothing to worry about i have driven many a standard R32 and theyr all the same.
A full exhast system with dump and hi flow cat give a bit more in the top end.
my 32 done the same. i had cat back exhaust at first. i finished it off with a turbo back system and defo felt more gains, esp midrange to top end. still same boost though.
then put a fmic on. at first it *still* dropped the boost. but now, for whatever reason, it holds a steady 12psi...
no controller or anything.
i think its just normal. many posts on here saying that drop boost (even me! :D)
s.
Mine does it too, I was worried about it aswell.. i'm running at 12psi stock turbo..have a FMIC and pod.. and catback exhaust It just feels like its restricted or something.. if its normal then thats ok... I was stressing i was f**king the turbo. somehow..
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
