i would go the 33 gtr. Unless of course i could get my hand on a vspec 2 r32 gtr. Fat chance getting one of them tho :)
I drive my 94 R32 GT-R almost daily. I went and looked for the cleanest, best condition version I could find.
Even with a full race seat and heavy springs it's still nice to drive. I get in my VY SS and it feels like a tank.
What ever you do, get someone who knows what they are doing to check it out before you sign up - no matter what the model is.
Regards
Andrew
Edited by BBGTR
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1778695
i drive mine on a daily basis. i have no trouble what so ever. never driven a 33 gtr but i like the 32's better. i have an 89 and have no problem with it. if you want an 89, you will have to do some searching for a bog stocka for it to be any good. good luck
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1778845
Hey all the GTR'S are really nice.Now i really do have a feeling that many sources tend to undermine r33 tiny bit.Look it is roomier car, to my taste it beats the look of r32 any time. Interior is much better in r33 and overall looks alot better. I m certainly not canning r32 as it is a damn mighty car. Now regarding r33 missing the performance. Here is something interesting if you look at performance stock to stock, R32 comes ahead of r33 and r34 0-100 and 1/4 mile.Ok now you think whay would u pay 10 grands or more for R33 or R34 when i get more with R32. Well if you start modifying you will soon realise that scale quickly turns the other way around and R32 comes last.Remember 33 and 34 are newer, newer and more sophisticated engines, turbos ecu's attessa systems.Who ever tells you that they arer all the same the talk sh......t. At the end of a day as said previously it is a matter of taste and convinience.As mentioned r33 broke Nurburgring record in 1995 and that should be telling you something about this "Unexillerating car" :)
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1781315
Thank you very much for all of your input :-)
If you are after an R32 there are plenty of good ones around. Don't be put off by the "all '89's are crap" brigade as this is patently false. Having said that my '94 model (For sale too!) is set up as a daily driver - most GT-R's have had modifications done to them that makes them less liveable on a day to day basis. If you choose one that is unmolested then you will be happy with it day to day.
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1786367
94 GT-R daily driver and For Sale eh ??
Pity it's not March yet otherwise I'd be really tempted - as opposed to just tempted :P
I might PM you in the new year to see if it's still available :D
Oh and thanks for the info
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1788271
Pity it's not March yet otherwise I'd be really tempted - as opposed to just tempted  :D
I might PM you in the new year to see if it's still available  :(
Can't hurt. I am going on holidays for most of January, so given I am not trying real hard at the moment it should be around in the new year.
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1788834
If you really want to tease me send a quick run down of specs, possible price and maybe a pic or two via PM - you never know....... :)
https://www.sau.com.au/forums/topic/97445-feral-hun/page/2/#findComment-1789271
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
