That's right, I got a parking ticket for pulling over into an "authorised vehichles" area instead of blocking the princes highway in peak traffic when I broke down.
To give you guys some background, a couple of days after I checked over my car, I gave it some boost (first time since I bolted the car back together) and managed to blow one of the induction pipes off - the one that goes to the steel L pipe that the BOV bolts on. Anyway, I decide to pull over into a quiet section on one of the driveways for Rockdale Plaza at the first available place I thought safe. I popped the hood and confirmed my suspicions and came to the conclusion that I needed to tighten up the hose clamps.
Now I live just around the corner and up the road a bit, but the catch is it's 4:30pm on a weekday and the Princes Highway (which I'd have to drive on) has heavy traffic - as per normal. So I send the missus around for my tools (lol) and while I'm waiting for her to come back, I get snapped by a driveby inspector. And the fine and happy-snap show up 2 days later.
Now I think I have a reasonable excuse for "standing" my car there. So who here has been in a similar situation, and what did you do?
https://www.sau.com.au/forums/topic/98341-parking-ticket-while-broken-down/
sort of similar.... the towtruck could only leave my car in a no standing zone outside the mechanics at night, as it was closed. went down the next day and left the keys with them but the lazy pricks didnt move the car for 2 days.
Anyway I coped a fine, and I didn't even have the keys to the car. I've sent a letter enclosing the copy of the towtruck receipt and the invoice for the repair to the infringement bureau, but apparently this isn't sufficent evidence (what the f**k is, I ask....) anyway I'm calling them in tomorrow to find out what other possible evidence they need that A. the car could not be moved and B. I didn't have the bloody keys....
write a letter and enclose as much evidence as you can... you might just get off...
Edited by Archie@
something like that happened to me.. except i parked in a no standing zone on purpose for a job interview (was running late).. i came back to see a parking ticket on my windshield.
i disconnected my battery, called the nrma to "fix" it, got them to print out a statement for me and sent it off with a letter of appeal.
fine was taken off my record.
Very smart mate! Good on you! It's about time someone got one back!!! :lol:
So i guess this is why I've had to wait over an hour for NRMA before...... It was your own fault that you parked there... slightly different to the above to examples... Although it is a miss use of resources, I got to admit its very clever...
I got a parking fine in front of my house. $125. Something about parking opposite of direction of trafic. It's a very quiet street and I've been parking like that for 4 years and this was the first time. Not happy.
Edited by nedb
I got the EXAct SAME FINE! I was parked in a quite back street in Zetland facing the wrong way. The street was only wide enough to park on one side but it was 2 ways. I was away from the car for 10mins at 11pm and there it was waiting for me. Some council ranger must have had very little to do at 11pm at night.
I was fined for overstaying my welcome in a 2h spot outside the public hospital - whilst I was inside helping deliver my second little girl!
Appealed.
Denied.
Wankers.
And Airzone, that sucks when you have no option but to pull over. Here's hoping you are excused but without any evidence being available you'd be doing well to pull it off.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
