im in the process of buying a series 2 manual stagea through j-spec.com.au
are there many other stagea owners in nsw?
ive got a maximum budget of 950,000 yen FOB, do you think i am likely to pick a nice example for that kind of price?
https://www.sau.com.au/forums/topic/98555-im-buying-a-stagea-s2-manual/
  • Replies 190
Posted Images
You will get nothing but crap for that type of price ie accident damaged etc etc. You normally would need to spend 1.3 to 1.4M yen (or higher) for a good condition Four S...
Ian
Thats what I was thinking Ian.... under $1m yen just isnt enough for a S2 manual, maybe ok for a S1 auto.
For a nice condition version s2 manual a minimum 1.5m yen would be needed. For Sure. Or buy one already imported, for 25k or less.
I would be extremely surprised if you could get a "four s", already imported, for $25K - in reasonable condition! Read http://www.skylinesaustralia.com/forums/in...showtopic=73058 from start to finish... Especially my post at http://www.skylinesaustralia.com/forums/in...8entry1378058
Ian
Edited by ian
thanks funkymonkey, and a special thanks to J-Spec.
yesterday i won a silver s2 rs four s manual with a rating four, check out the pics.
it has a bodykit with 260rs front bar, aftermarket suspension, aftermarket exhaust, and rims.
Good luck with it, however in my experiance, ive often found the great bargains in the world end up being not so great ...
But, dont fret, i am sure its only because its higher KM that the price was that low. Good luck with it and cant wait to see it on the road.
What city is it coming to?
yesterday i won a silver s2 rs four s manual with 110,000 kms with a rating four for a mere 760,000 yen FOB, check out the pics.
I assume the auction report you have has the vin number and the production year (both missing from the one you posted). If you PM the VIN number I'll check it in FAST to tell you exactly what the model/year is.
And don't forget for compliance you'll have to put normal suspension and exhaust on etc etc.
Excellent buy if it turns out OK (which hopefully it will!)! Keep us all informed.
The VIN number is on the auction report, its just been split into two places as this auction does. Its WGNC34-122104, which is a 10/1998 built RS Four S.
yes i am aware that the exhaust suspension and wheels need to be changed over for compliance but i will get the workshop to put it all back on once complied, and i have allowed for this extra cost in my budget.
the stagea will be imported to QLD then once complied it will be transported to my place (Western Sydney)
so are there many other stagea owners around sydney? and are any of them involved in the SAU NSW car club? as i am interested in joining once i have gotten my car.
Out of curiosity EGA41T, I take it you would need to borrow the exhaust/wheels/ whatever else is modified from the compliance place to get rego.
Now does that mean that it needs to have the stock parts on when you get it checked in Sydney? Meaning you need to get the car trucked down to Sydney, then send the stock parts back to Queensland?
Sorry.. just trying to make some sense of it...
if its complied in QLD , it will need stock parts at the time of complience , then these can be removed and aftermarket parts added back before its shipped down to sydney . Once its in nsw it just has to meet roadworthy requirements to be registered
yeah pretty much, it has 17" rims standard so i could have upto 19" rims and still wouldnt be a problem with rego
although i have no idea how loud it will be so that is another issue.
does anyone in nsw know if you need to get a blue slip after the vehicle is complied in brisbane to get it registered?
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
