  • Replies 190
Posted Images
lol noice camo front bar, driveways are gonna soon become your most dreaded enemy.
The foglights are most probably disconnected from when they took the bar off, do the front indicators work?
the front indicators are working so ive got no idea why the foggies arent...although i havnt really had a chance to get a decent look at it
i'm getting the blue slip done at 8:30am tomorrow so hopefully i'll have it registered by lunch time.
yeah no worries, feel like cruising out penrith way? i usually do a bit of cruising on a thursday night if you have nothing planned tomorrow night?
This...
is an alternative spot to plug this torch in (I think)...
Ya lucky bastard :P - I saw a Stagea with one of these at Edward Lee's, and one of the salesmen there showed me. I think there might be other things you can plug into it as well, but not sure. When we get our parts list CDs from Funky we should be able to find out if that's the case.
This...
arrrrrrrrrrh, nice pick up. that would be pretty cool if you could plug in other things aswell. the torch that is on the side swivels to point in the direction that you want it, which is pretty cool.
i folded down the back seats and closed the rear hatch and had a lie down in the back this afternoon, i must say there is HEAPS of room in there.
i also reclined the rear seats when they were still up, they go back a fair way, would be perfect for lying back and watching a roof mounted monitor if i was ever to install one
ive also had a bit of a muck around with the radio, sre there any decent FM stations under 90.0???
there are a couple of half decent stations on AM but they arent that great
and i figured out how to use all of my lights, it must look funny to someone coming towards it with all six lights on.
Probably not, but there are some pics somewhere in the Stagea threads with a mountain bike lying down in the back with both wheels on. I think it's a brochure or something... I will post a link in a minute...
i just went out and got a photo of it
unfortunately i was lucky enough to get the rust under one of the mirros, but i'll probably just get that fixed when i do the front bar
nothing was wrong, there was en extra wheel half way along the indicator stork that i didnt notice before
i still need to sort out why i cant control the passenger front power window from the passenger seat, but i can still do it from the drivers seat switch panel, maybe the switch is unplugged or something
The rear seat reclining is tops!
You need to get a converter for the radio (if you haven't already) - Jaycar sells them. Triple J is 89.5 or something, that's the only station I listen to.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
